are these the correct beige injectors??
11 posts • Page 1 of 1
i have just managed to get hold of the injector rail from a 2.0 zetec mondeo the injectors colour is beige, are these the correct beiuge injectors to use in a rs turbo fiesta?for 195 bhp??? let me no asap plzzz cheers
- bigtazzsi
Can you post the part numer from them and I can check. I would think they will be no use as Zetec injectors are fed differently iirc
Mine before fitting
Mine before fitting
There are two numbers on my injectors.
570
80150701
I beleive the second one to be the important one.
Best go tidy up the garage now seeing as I fell over the bucket that didn't get put away properly
570
80150701
Definatley not the correct injectors.
Completely different unfortunately.
The beige '701' injectors usually fitted with the 195 chips, are standard fitment in the E36 BMW M3.
Steve
Steve
- Captain Tightpants
- Avinitlarge
the correct beige injectors should be:
Bosch 0.280.150.701
this is where the term 701's come from..
colour beige
240cc
16 Ohm impedance
est 48 BHP/injector
These are the 'ones' to be fitted when using a 195 chip (incl a cossie fuel pump)
injectors can be found in
3 liter BMW M3
3,5 liter BMW M5
Citroen Xantia 2.0 Turbo
Alfa Spider 2.0 Turbo
Bosch 0.280.150.701
colour beige
240cc
16 Ohm impedance
est 48 BHP/injector
3 liter BMW M3
3,5 liter BMW M5
- Jur
