Avo coilovers cossie brakes 300mm rst hub conversion
Postby fezzRS on Thu Feb 12, 2015 8:44 pm
Avo coilovers need a refurb 120
Cosworth brake setup discs pads calipers carriers bolts £130
Rst hubs drilled to take a 300 mm brake conversion nedss new bearings £80
Your car: run about
Re: Avo coilovers cossie brakes 300mm rst hub conversion
Postby mikeymikeyp on Fri Feb 13, 2015 4:09 pm
coilys mk 3 or 3.5
mikeymikeyp
Postby fezzRS on Sat Feb 14, 2015 12:12 pm
Powder coated fuel tank 80 has few dents
Luk clutch disc £20
Driveshafts £60
Mk3 coilovers need a total tefurb without cups £80
Helix pressure plate £50
Hubs drilled to take bigger brakes £80
Your car: run about
