AW3K and Tora1023's fiesta bertie
Re: AW3K and Tora1023's fiesta bertie
Postby rsturbonutter on Tue Sep 04, 2012 10:45 pm
Tomorrow old chap I will get you one
rsturbonutter
Your car: Fiesta RS turbo
Postby AW3K on Mon Jun 30, 2014 9:27 pm
well i bet most of you thought this was dead . it certenly isnt
birth of my son etc
made a little progress but as most parts had been stored in a leaky garage it got damaged, mainly the gaskets
first up my local motor factor is a star they let me draw round a gasket from a new pump. no where but ford sold the gaskets separate, not paying £12 ish for a bit of paper.
pump fitted
new inlet gaskets
new looking maf and throttle body and box of hoses and bits
finally some more of the wiring re-taped
ordered all stainless steal fixings which should be here tomorrow, also changing the colour of the cam cover and sump.
AW3K
Postby AW3K on Fri Jul 04, 2014 9:03 pm
bit more progress
some bits painted in high temp paint
egr blanked off and manifold fitted with new studs and nuts
finally i had some new stainless braided ptfe fuel injector lines made up about £7 each from my local hydrolics place
AW3K
Postby Smo on Fri Jul 04, 2014 11:14 pm
Liking the fuel line, Andy!
I assume it's all rated for high pressure unleaded/biofuel?
Smo
Postby AW3K on Sat Jul 05, 2014 8:01 pm
Smo :Liking the fuel line, Andy!
its same ptfe inner pipe stainless overbread fuel/oil/deisle rated made professional by mend a hose
http://www.mendahose.co.uk/
pushed on and crimped.
AW3K
Postby AW3K on Sat Jul 05, 2014 8:32 pm
both hoses test fitted and clamped down to the original bracket
you may have noticed the rocker cover has changed colour lol
also the rail and hose ends are getting polished
AW3K
Postby AW3K on Fri Jul 18, 2014 9:19 pm
Non Pas altonator mount arrived cleaned and painted
need a new alt now
Repainted the sump a nice satin black tidied it up no end
alt mount fitted , i used old head bolts to fix it, as i didnt have the bolts and i think it looks better.
timing tensioners fitted not looking forward to fittin the belt.
Fitted stainless bolts with antisieze compount
painted the rocker cover again and dug out the cross over
comments etc welcome
AW3K
Postby AW3K on Fri Jul 25, 2014 9:18 pm
Fitted tining belt and sorted the timing. Never want to do that again.
AW3K
Postby jayrs on Sat Jul 26, 2014 12:07 am
Lol mate reminds me when I fine mine seeing all the stuff piled on there lol
Timming up a Zetec is a bit if a paint ain't it
Postby AW3K on Sat Jul 26, 2014 10:16 pm
jayrs :Lol mate reminds me when I fine mine seeing all the stuff piled on there lol
I forgot how much of a pain it was. It's done now thank god.
This is the wife's car. Mine has stuff piled on it aswell.
AW3K
Postby jayrs on Sat Jul 26, 2014 10:56 pm
Lol dude you wanna see my xr2! Lol
Postby Smo on Sun Jul 27, 2014 10:25 am
Does the alternator not use the bracket as its earth route? Or have you still got unpainted areas of the bracket where it mounts to the block and alternator? Just looked like you'd painted the entire thing from the photos! :)
Smo
Postby AW3K on Sun Jul 27, 2014 9:17 pm
Hi Simon. Long time no speak. Yeah the back is unpainted so are the mounting points on the block.
I do need to remove some paint from where the alt bolts to the mount.
AW3K
Postby AW3K on Sat Sep 06, 2014 7:30 pm
few more bits painted and fitted
chemical welded the mounts on the cam cover and stainless fixings again
AW3K
Postby niracka on Tue Oct 14, 2014 10:45 am
Looking good Andy now get it finished!!!
Long time no speak mate hows things? Thinking of getting a fezzer to play with in my spare time.
olly
niracka
Your car: E46 M3
Previous
