AW3K's 2.0L XR2i, rust restoration
Re: AW3K's 2.0L XR2i, stainless
Postby AW3K on Mon Feb 22, 2010 11:54 pm
niracka :just the rears????
yeah the rear discs
AW3K
Postby niracka on Tue Feb 23, 2010 1:10 pm
Yea sorry mate I dont know I'v got drums on mine. I'l try n find out for you thaugh.
Ollie
niracka
Your car: E46 M3
Postby AW3K on Wed Feb 24, 2010 1:07 am
here is another bit closer
rs2k carriers, no washers needed , only bigger bolts
braided line
bout 5mm clearance on my 15inch rs7's
about 1mm clearance on my 14inch rs7's
plenty of room on the escort alloys
ordered some bits , hopfully getting them on sunday
AW3K
Postby AW3K on Mon Mar 01, 2010 9:23 pm
thanks to dave for these :)
hook end
as you can see the cable is too long, well maybe
so i may have to use these
AW3K
Postby AW3K on Sat Mar 06, 2010 12:08 am
ended up getting the wrong cable (yoke and no adjusters) , so back it went , got right one this time
new cable has the correct end and adjuster
here we go, hub fitted
caliper fitted
line fitted , i ordered the custom made one but it looks like if you have a lowered car the originql one may reach from the car to the caliper
AW3K
Re: AW3K's 2.0L XR2i, focus rear discs
Postby knuckles on Sat Mar 06, 2010 12:43 am
nice progress andy. :Q
knuckles
Your car: Fiesta Rs turbo
Postby jonyb4 on Sat Mar 06, 2010 5:47 am
looking good
if that braided line has a fair amount of slack, but as you say because its lowered, leave it on mate, mine failed the MOT due to when the car being raised on jacks the lines got to tight on the rear, and if it ever has its standard suspension put back on your gonna have issues
Postby AW3K on Mon Mar 08, 2010 11:27 pm
these bad boys came today :)
20inc long with male and female ends oh yes £25 posted for the pair
top quality as well
its getting there
AW3K
Postby jonyb4 on Tue Mar 09, 2010 1:55 am
yay you can get cracking now :)
the race is on mate :devil:
so i figure you could make them into a necklace if you wanted? :P
Postby AW3K on Tue Mar 09, 2010 6:18 pm
jonyb4 :yay you can get cracking now :)
lol somet like that, wanted them to connect to the goodridge ones i have so custom was needed
hurt my foot so cant do any more till it heals
AW3K
Postby jonyb4 on Tue Mar 09, 2010 8:40 pm
yes! lol dont take this wrong but im in a delay also :P cant have you gaining on me lol
man flu's got me slowed :rolleyes:
Postby AW3K on Tue Mar 09, 2010 11:11 pm
lol a right pair lol
ill get it sorted
AW3K
Postby AW3K on Wed Mar 10, 2010 8:37 pm
the escort yoke has to be swapped for the fiesta one as it wont fit in the channel.
flexy hoses connected,
all set up baring the hand brake till i get other side on cos of the tension.
AW3K
Postby jonyb4 on Wed Mar 10, 2010 9:10 pm
nice man, looks a bit liek spagetti junction but :P
shalt be long now :Q
Postby AW3K on Wed Mar 10, 2010 9:19 pm
gunna tie wrap the long one to handbrake cable when its fitted correctly
but if it works :)
AW3K
Postby Minstral on Wed Mar 10, 2010 10:20 pm
just a thouhgt andy but why didnt u just get some custom lines that ran from arch connector to the brake.
Minstral
Your car: *
Postby AW3K on Wed Mar 10, 2010 11:40 pm
Minstral :just a thouhgt andy but why didnt u just get some custom lines that ran from arch connector to the brake.
the single long pipe i thought would have caught my wheels, this way i can tie it back
either way it works :)
AW3K
Postby jonyb4 on Thu Mar 11, 2010 12:12 am
well if it helps, the mk4/5's are as toby suggested, theyre chassis to hub lines, no rubbing issues
Re: My First XR2i - engine out
Postby rs-tom on Fri Mar 12, 2010 2:50 pm
niracka :That pic is quality mate :lol: :lol:
how did fabio copello get in ur engine bay
rs-tom
Postby jonyb4 on Fri Mar 12, 2010 6:59 pm
haha :lol: :lol:
lol andy it looks like your photoshopped in
Postby AW3K on Fri Mar 12, 2010 9:31 pm
lol every one says that im photoshopped but im not , i was trying to clen the cross member lol
little update
drivers side on and handbrake cable fitted, feels quite sharp
system needs bleeding but bat is dead so cant create a vacum
had to replace this part of the copper pipe as it wouldny come undone from the flexi
body kit back on on pass side :)
more to come
AW3K
Postby jonyb4 on Sat Mar 13, 2010 1:32 am
eek, the end is in sight
Postby AW3K on Sun Mar 14, 2010 10:11 pm
its alive mwahhh
http://www.youtube.com/watch?v=uL-5FOR1glk
need some dot4 now then i can bleed the system
end is close
AW3K
Postby jonyb4 on Sun Mar 14, 2010 11:21 pm
woot, lol you say end as its gonna be crushed or soemthing :P
the beginning!
andy i think you should deffo paint the rocker red! :) the standard greyish metal is :aaah:
Postby AW3K on Mon Mar 15, 2010 10:17 pm
jonyb4 :woot, lol you say end as its gonna be crushed or soemthing :P
the beginning!
yeah the end is close....
got new tyre's on alloy 195 / 45 / 15 and a 14" steelie with a 185 / 50 / 14 tire
bled brakes , secured the cable, fixed the fog light ....... booked mot tomoz at 4pm so got time to clean it before
AW3K
Postby HCS PIMP on Mon Mar 15, 2010 11:26 pm
andy have u got a new phone tried ringing you a few times recently to no prevail lol
you stil have the old faithful xr2i
i have a fez again as u may have noticed :P
this ones maybe going to last longer than the other 3 i hope
HCS PIMP
Postby AW3K on Tue Mar 16, 2010 11:08 pm
HCS PIMP :andy have u got a new phone tried ringing you a few times recently to no prevail lol
yeah still got same number, best bet is texting me as i cant answer calls much with work
hows youu?
car failed mot due to brake pedal spoungy and rear brake inoficant , needs adjusting
AW3K
Postby jonyb4 on Wed Mar 17, 2010 1:31 am
oopsy, but easy stuff
Postby HCS PIMP on Wed Mar 17, 2010 1:47 am
lol spongy brake pedal that will be a lovely bubble or could just be they need to bed in
HCS PIMP
Postby jonyb4 on Wed Mar 17, 2010 1:54 am
i find that brakes and clutches sometimes need bleeding twice to be perfect
Postby niracka on Wed Mar 17, 2010 1:26 pm
Yea you could ahve just had a bubble or two stuck in the master cylinder or something. I had to bleed mine twice last time to get it right :rolleyes:
Glad to see her coming on anyways man. Be good to see you again soon. I'l drop you a line next time I'm up that way.
Ollie
niracka
Your car: E46 M3
Postby AW3K on Wed Mar 17, 2010 9:25 pm
ollie no worries mate, will be good to see you
need to fit a mondeo master cylinder to componsate for the double sized front calipers and the 3/4 times larger rears, compared to the drums
AW3K
Postby AW3K on Fri Mar 19, 2010 12:53 am
before
after
size differance , mondeo on left fiesta on right.
some pipe work has to be altered but not too bad
cant connect it all up till i get a new seal
AW3K
Re: AW3K's 2.0L XR2i, focus rear discs, mondeo servo
Postby jonyb4 on Fri Mar 19, 2010 1:15 am
looking good, should help push them stoppers now
Postby AW3K on Tue Mar 23, 2010 12:30 am
plumbed in now :)
handbrake adjusted as well
AW3K
