Awful Ride!
5 posts • Page 1 of 1
Awful Ride!
Since I put my 16"s (195/50/16) on my car you feel every bump in the road, as I would have expected. Still got standard suspension on my car, so what suspension would people recommend to make the drive a bit less bumpy, bearing in mind i want to lower it at least 40mm.
- mattyashy
Ride comfort is traded off in the intrest of handling and performance. Assuming you are on a aMk3 or 3,5 Fiesta your tyres are th ewrong profile, you really should be using 195/45/16 or better still 195/40/16.
You just won't get the drop you want and retain a nice comfy ride I'm afraid
The best compromise would be to use 4 brand new standard dampers or Koni top adjustables set to soft and use a progressive rate spring with no more than a 25mm drop
