baily breather
baily breather
Postby mikeymikeyp on Sat Feb 22, 2014 7:28 pm
How do you rig yours up to a cvh and do u use a filter on 1 of the pipes
mikeymikeyp
Re: baily breather
Postby rsturbonutter on Sat Feb 22, 2014 8:36 pm
Just put a small filter onit or vent to atmosphere without one
rsturbonutter
Your car: Fiesta RS turbo
Re: baily breather
Postby mikeymikeyp on Sun Feb 23, 2014 8:51 am
Thats what i thought it was more the bottom pipe i was wondering what people do with that
mikeymikeyp
Re: baily breather
Postby russ-RST on Sun Feb 23, 2014 12:02 pm
How many outlets do you have? Most people route the bottom outlet round the to back of the block and into a T piece which then connects to the right hand rocker cover port and the breather from the block down underneath here, ..
My breather had. 5 ports to I ran mine . 1 to left hand rocker cover, 1 vents to atmosphere, 1 is used as a vacuum on the inlet, 1 runs to the right rocker cover and the last one runs straight to the block breather . And I found its way run better although I'm not sure if mine is supposed to have. 5 ports or 4
Hope some of that helps
Russ
russ-RST
Your car: fiesta rs turbo
Re: baily breather
Postby mikeymikeyp on Sun Feb 23, 2014 2:12 pm
spot on mate thats what i thought cheers
mikeymikeyp
