Beige injectors maxed out????
6 posts • Page 1 of 1
For a 2.1 zetec turbo what sort of limit are beige injectors maxed at??? as this could determine if i use the standard ofab management.
Chris.
Chris.
- Brammer
- Your car: Sierra Cosworth
beiges are maxed out at around 220-225bhp iirc
for a zetec turbo you ian howell can supply suitable injectors... ford motorsport ones are also availiable
gary
gary
- garyhurn77
- Brammer
There's an enormous range of Ford Motorsport injectors, which are you talking about? The reason your current management is "limited" is because of the amount of positive pressure (i.e. boost) it can sense. The injectors don't determine that. What's happening with the ZT? Are you buying a pre-built engine? Will Ian be building it? If the latter, speak to him and you will come up with a spec between you.
As said anyway, beiges shouldn't really be pushed much past 220bhp. What power output and/or boost are you looking to run? You'll always find injectors to cater for your power requirements at these levels. Is there a particular reason for you wanting beiges so badly?
- Xr_Dub
