beige injectors with P0 superchips
4 posts • Page 1 of 1
i bought the p0 chip, plugs and 701's but i don't know if i have to use the p0 or the p1 with 701 what is better?
Is there a problem if i fit these together?
forgive my english cause i'm a french owner of a lefthanded fiesta turbo!
- GTO78
The standard injectors will cope with up to 14-15psi but that is them at their limit. If you are going for more than that i would recommend changing your injectors and dont forget to upgrade the fuel pump
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
you have the wrong chip my friend
a phase 0 superchip is a 165 chip ! this just kills the ECU's built in limiter !
to control Beige 701 injectors you will need a Phase 1 or 195 chip or better still something like a Ahmed Bayjoo chip or a Unichip (I know... ).
sorry geeza ! also you need to make sure u get the right chip for ure ECU !
- MadcatCraig
- BANNED SELLER
heres the stuff from <!-- BBCode Start --><A HREF="http://www.superchips.co.uk" TARGET="_blank">www.superchips.co.uk</A><!-- BBCode End -->
Results of my car search for -
Make : Ford
Model : Fiesta
Engine : Turbo.
There has been more than one match.
If the same model has more than 1 application available and you are unsure of which one you require, please check with your local dealer.
The following list of Superchips available is delivered in alphabetical order.
Ford Fiesta RS Phase 0 +30 bhp £350
Ford Fiesta RS Phase 1 +60 bhp £695
Make : Ford
Model : Fiesta
Engine : Turbo.
- MadcatCraig
- BANNED SELLER
