belgian xr2i 2.0l zetec (13/03/12) megasquirt ecu
158 posts • Page 3 of 5 • 1, 2, 3, 4, 5
Re: belgian xr2i 1.8 16v (24/09/08) fan
it's alive again
i'll have to say, it sounds like a beast
and it drives much better than before, fast throtle response, and it pulls through the revs like hell
the new fan in place
st170 manifold
just missing the starter
had to chop a bit from the carter to alow the lamda to fit
the rest of the exhaust
little sound clip
http://img531.imageshack.us/my.php?imag ... 002ow1.flv
greetz
st170 manifold
little sound clip
greetz
- dj_yd
- dj_yd
Re: belgian xr2i 1.8 16v (20/10/08) timing belt
looking good mate
loving the manifold
loving the manifold
- jonboisescort
Car: 1994 Ford Fiesta
i removed the belt again and changed the waterpump while i was at it
old vs new
all fitted back and running again
i bought a cross-over from a frst and modded it
as i got it( it's modded to fit a zetec rocker cover by area six)
and how it is now
removed the pipe on the left and welded 2 holes up and from "turbo" to "RS"
not ready though
greetz
old vs new
and how it is now
not ready though
greetz
- dj_yd
Re: belgian xr2i 1.8 16v (05/11/08) waterpump
a small update, not much happend to the fez , just driving it
i did got the broken koni shock back from koni after 3 months, got it true mot.
for now i'm collecting parts for a 2.0 conversion and a gearbox rebuild with lsd
escort mk4 lsd
2.0 zetec maf
2.0 zetec desk ecu
oil temp and oil pessure gauge + oilfilter sandwichplate for the sensors
greetz
escort mk4 lsd
2.0 zetec maf
2.0 zetec desk ecu
greetz
- dj_yd
- dj_yd
- dj_yd
Re: belgian xr2i 1.8 16v (19/07/09) 2.0zetec+lsd
just read the whole thread as i have never seen this before, well done mate a lot of hard work has gone into making this car
keep us updated with the 2l build!!
- dangerousdave
dangerousdave :just read the whole thread as i have never seen this before, well done mate a lot of hard work has gone into making this car
thanks mate
- dj_yd
a bit more
cylinder head cover of
at first site all looks good, when i removed the cams 1 of the bearingcaps had som blue colloring on it and there where some with marks on them, and where the camshaft meets the bearing there where some marks on them
the cams have been out before because the bearingcaps where marked, but when they refitted them they where possisioned the wrong way, i suspect this is the reason for the faults, and bad oil ofcourse
the bores and tops of the pistons look good imo
head of
sump of
gReetS
head of
sump of
gReetS
- dj_yd
- dj_yd
Re: belgian xr2i 1.8 16v (13/08/09)GAZ coilovers
that is beautiful
- xr2irhys
Car: 1996 Ford Fiesta Classic
- dj_yd
- dj_yd
- dj_yd
- dj_yd
- dj_yd
Re: belgian xr2i 1.8 16v (22/10/09)piper cams
all very good work there but i would recommend getting some after market ecu then she will fly !
- frostie
frostie :all very good work there but i would recommend getting some after market ecu then she will fly !
i'm planning to build a megasquirt ecu, only need a base map for it then and see from there, you don't have one maybe?
- dj_yd
- dj_yd
- dj_yd
Re: belgian xr2i 1.8 16v (17/11/09)fiestaST brakes
Nice, love st brakes , also love the colour
but if you're planning on doing a rear disk conversion you have to know somebody at Goca (MOT in Belgium) because it's illegal to do that
Stupid laws in Belgium
- zottenbarryfrst
thanks for the repley
i'm not going to use rear disks, they are not mot proof in belgium, same as the front disks.
gReetS
gReetS
- dj_yd
- dj_yd
- dj_yd
Re: belgian xr2i 1.8 16v (31/12/09)2.0 honed and flowed head
and finaly started the rebuild
new pistonrings after checking the gap clearance
new main bearings
crank in
the crankshaftseal housing
cleaned up
gasket in place
the housing mounted to the block
and the seal in place
ARP conrodbolts vs OEM
newbig end bearings
nr1 and nr4 in
i checked the running clearance on the main and big ends and checked the endfloat, all was well
new main bearings
crank in
cleaned up
gasket in place
newbig end bearings
nr1 and nr4 in
- dj_yd
new o-rings for the injectors,ford head bolds and new pistonjets
new 1.8 fiesta waterpump
4 pistons in
pistonjets
i cleanedthe feulrail
got the injectors in the feulrail , al new seals
i than matched the sandwich plate runners to the ports and gave them a mild pollish
also i mached the inlet manifold to the sandwich plate
thats it so far
hope you like and if you see something thats not ok then please tell me
4 pistons in
pistonjets
thats it so far
- dj_yd
Re: belgian xr2i 1.8 16v (11/03/10)2.0 rebuild
cleaned and painted HO inlet manifold
painted the sandwichplate
cleaned and painted the throttlebody ,pollished the inside, pollished the butterfly and knife edged it, also made the inlet edge smoother
before
after
cleaned and painted the sump
i bought a oil pickup-pipe, when i recieved it the wiremesh was out
so i chopped the 2.0 oil pickup-pipe and got that mesh and got it in the 1.8 pipe
new oil pump
before
after
new oil pump
- dj_yd
Re: belgian xr2i 1.8 16v (14/06/10)2.0 rebuild
the latest updates
oil pickup-pipe fitted
new gasket on the clean sump
sump fitted with some stainles steel bolts
[IMG=http://img44.imageshack.us/img44/9190/picture004gj.jpg][/IMG]
new 1.8 waterpump
skimmed block
headgasket
head and piper cams ready for fitting
ported and flowed exhaust port
ported and flowed inlet port
head on block
piper cams fitted
now i need to sort the timing and the 2.0 is ready :mrgreen:
gReetS
new 1.8 waterpump
skimmed block
headgasket
head on block
piper cams fitted
gReetS
- dj_yd
Re: belgian xr2i 1.8 16v (15/06/10)2.0 almost build
my latest update
i have some vernier pulley's , i only had to drill a hole to match the piper cams so i can fit the dowel's
pipercams
drilled the hole in the pully
pully on and locked with the dowel in place
al timed up
a new ford timing belt
i painted the timing covers and moddet the upper cover so you can see the pully's
than started on the inlet manifold
gasket in place
the sandwichplate and injectors in place
the other gasket
and the HO inlet on
and this is how it will look
a few litlle things and its ready
gReetS
pipercams
al timed up
gasket in place
the other gasket
and the HO inlet on
gReetS
- dj_yd
Re: belgian xr2i 1.8 16v (13/07/10)2.0ZETEC
awsome mate
love the cam cover
- jonboisescort
- dj_yd
- dj_yd
jonboisescort ::Q
awsome mate
love the cam cover
thanks mate
- dj_yd
Re: belgian xr2i 1.8 16v (23/09/10)front end rebuild
Awesome as usual
- Sphinx
