Best boost gauges?
27 posts • Page 1 of 1
Best boost gauges?
Looking at getting a boost gauge for me fezzy, but don't know which one is the best?
I quite like those ones that have the silver/chrome circle round the face. Can't remember the name, but can anyone give me sum advice!!??
- EvilFranky
Be different and go for a jap-style Blitz indigo-faced item
it will look te nutsack, and be well accurate cos they definitely know what they are doing
but hey, its only as accurate as the monkey who fits it
Whenever you have doubts about whether to spend money on your car or on food 'cos your stomach is rumbling...remember...
"ITS GOTTA BE DONE!"
- ItsGottaBeDone
If you look at http://www.greengauges.co.uk you can design your own.
I've got a CAI boost gauge and it is pretty accurate after I fitted an extra rubber washer bewteen the gauge and the hose fitting because it was leaking. Not the best night time illumination though.
John
John
Quantum H4 2.1 ZVH Turbo - FOR SALE
Group4 Escort MkII 2L 16v
- Quantum John
Defi gauges are the absolute t1ts!
Go to http://www.defi-shop.com to learn more.
Specifically check out the "Defi link system".
Just look at it!!!
[img]http://www.fiestaturbo.com/phpBB/gallery/DuncanFRSTtb115w[1].gif[/img]
Just look at it!!!
- DuncanFRST
Sunnys is a G-reddy boost guage
Kev myself and Phil M know ian howell who owns Racetek mention u know phil or steve with the black cossie for a discount lol
- MadcatCraig
- BANNED SELLER
Defi UK importer:
Nitosport
Mr. Marino Morelli
Pond Cottage
Chertsey Road
Windlesham
Surrey
GU20 6HT
Tel & Fax 01276 475878
E-mail: Ninosco@aol.com
Nitosport
Mr. Marino Morelli
Pond Cottage
Chertsey Road
Windlesham
Surrey
GU20 6HT
- DuncanFRST
Duncan,
I see from your night time picture you've got one of Mike Rainbird's ACT guages, no? I can't see from the photograph exactly where you have put it. I've just ordered mine and would like ideas on best place to put it.
Also where did you mount the sensor?
John
John
- Quantum John
DOH!!!
I've just realised that we are looking at an ERST dash board in the pictures and not a FRST one!
Still, good ideas on where to mount the gauge on the dash would be helpful.
John
John
- Quantum John
Ok Mr. Quantum John....
Although as you've correctly realised, I don't have the ERST shown in the pictures, I do, however, have one of Mike R's ACT gauges.
Do Quantum's have a Mk.3 Fezza dash then? If so, I found the best place to mount the gauge is to the left of the steering wheel, on the grey plastic under the dash clocks shroud. You will see a sort of curved-edge rectangle embossed into the plastic at this point. This marks the spot.
As for the sensor, I've mounted mine directly after the intercooler. I tried mounting it just before the throttle butterfly, but I found that when stationary the heat conducted from the engine would heat the sensor up so much that an accurate reading was impossible until I'd driven for about 5 mins afterwards.
Hope this helps.
Hope this helps.
- DuncanFRST
Follow this url for UK pricing information.
They're not cheap!
http://www.namotorsport.co.uk/defi/defiprices.htm
They're not cheap!
- DuncanFRST
The "Turbo with Control unit" costs £150 and is basically a 52mm boost gauge with the Defi link controller which is worth £75 on it's own. This is quite a good starting price methinks. All you then need to buy is the boost pressure sender unit for about £30.
After that extra gauges and sender units can be added to the controller at an extra £120 per gauge.
But, as you said, I defo think they're worth it as they are gorgeous!
- DuncanFRST
Duncan,
Cheers for your info on the ACT gauge. Just for your info the Quantum H4 that I have uses everything out of a MK3 Fiesta. I used a stuffed FRST which was never going to see daylight again (cos it pains me to see a perfectly good RS being broken).
The point in the dashboard you mention I can't use because I have fitted leccy mirrors and that's where I have put the Ford controller for them. Besides can you still see it while driving from there?
I've also ordered the sensor from Mike with a threaded end so that I can drill and tap the throttle plenum for best temperature results. Is yours drilled and tapped or tucked inside one of the hoses?
John
P.S. The defi gauges look the dogs whatsits. Has anyone tried the SPA digital gauges? Their turbo boost one includes a readout for the ACT.
John
- Quantum John
Quantum John :Besides can you still see it while driving from there?
I can see it from my driving position, yes. Sometimes, when cornering the steering wheel gets in the way, however.
Quantum John :Is yours drilled and tapped or tucked inside one of the hoses?
Mine is tucked inside the hose that goes from the intercooler to the charge carrier (T U R B O) pipe. I didn't get a boss to mount mine with. Still works a treat tho!
- DuncanFRST
