best cam for frst engine
21 posts • Page 1 of 1
as above looking to buy a cam kit for my little ka to help boost the power to around 200bhp
jus wondered what even one else is running and what are the main differences between say the piper, kent and the newman variety????
your thoughts would be greatly appriciated
- garyhurn77
i was just going to post a simaler question but i wanted someone to reccomend a performance cam to complement a polished and ported frst head with cut back valve guides but standard sized valves.
sorry if im hijacking your thread dude
- paradox
personaly kent cvh35 from an escort turbo. does me good and works well i you go T3.
- matty872
don't really matter to much I used that cam on my car for 2yrs only went T3 [ERRR] my turbo blew.
- matty872
personaly i would ask my tuner which one he would recomend for my engine spec.
A cam that works well in one engine can be horrible in another.
3dr Sierra Cosworth Track car
S1 Escort RS Turbo
- wildheart
I beleive there are subtle differences between the lift and the duration on the two cams. Ian Howell at Area Six will be the best man to speak to he explained it to me a few years ago
where is the best place to buy the cvh34/35 cam kit... i ve looked in the performnace ford magazines but every tuner seems to be pushing the 285t2 piper cam kit???
gary
gary
- garyhurn77
The 285T2 is s**t. Try the 35 and the T2 back to back and you will file the T2 in the bin. In fact I know somebody who did just that with a 500 mile old T2
garyhurn77 :where is the best place to buy the cvh34/35 cam kit... i ve looked in the performnace ford magazines but every tuner seems to be pushing the 285t2 piper cam kit???
gary
mine came from burton power.
- Shannon
Most people including my tuner (NMS) say the Piper T2 is crap but after setting my car up he reckons it works fantastic in mine and is the best driving RST he had driven!
So like i say engine spec will determin whats best for you.
S1 Escort RS Turbo
- wildheart
Piper t2 and kent 34 & 35 are good cams but are old skool, i run a 36 in mine and it the best of the 3 and i've used all 3 kents in my fiesta and a 285T2 in my old efi turbo orion.
If you want the best cam for a cvh on the market at the moment is a newman camshaft with solid lifters
- Brammer
- Your car: Sierra Cosworth
garyhurn77 :arent solid lifters a pain in the arse to set up though?
Not particularly just go on the system of 9 - e.g if 2 down set 7 and so on.
http://www.newman-cams.com/pdf/ford.pdf
£110 = cam
£128 = solid lifters
£45 = double valve srings 200Ib
£18 = fitting tool
total = £301
- Brammer
h196jne :garyhurn77 :arent solid lifters a pain in the arse to set up though?
£110 = cam
£18 = fitting tool
total = £301
thats just confused the hell out of me
- paradox
paradox :h196jne :garyhurn77 :arent solid lifters a pain in the arse to set up though?
£110 = cam
£18 = fitting tool
total = £301
What did mate???
- Brammer
1 down set 8
2down set 7
3 down set 6
4 down set 5
5 down set 4
6 down set 3
7 down set 2
8 down set 1
its referring to the lifter numbers!
2down set 7
3 down set 6
4 down set 5
5 down set 4
6 down set 3
7 down set 2
8 down set 1
- garyhurn77
£110 = cam
£18 = fitting tool
total = £301
Go to Larkspeed and get the Kent CVH34 Kit for £235! Bargain!
New Project In Progress!
- mintwhiters
- Your car: Moved onto Motorbikes
