Best Clutch??
16 posts • Page 1 of 1
Best Clutch??
I have a mk3.5 Fiesta si and its ready for a clutch so.... Im wanting to eventually run it on throttle bodies, but i dont really want to put a paddle clutch in it because you have to change my pedal to a manual adjust pedal. Would a organic clutch be able to take over 200bhp?? What would you advise thanks [/u]
- clarks.2007
id say alcon 6 paddle all the way, in my friends frst he put an alcon 6 paddle on and is still using the standard fiesat ratchet pedal on it now. lasted fine
finally im back in a fiesta turbo after a headache of building a bmw turbo
- fizzyturbo
Organic clutch would be my choice every time.
I run a Helix organic clutch in my 260bhp S2 and that's never slipped regardless of what I do to it.
Or there's the 4 paddle from techniclutch. That's pretty amazing. Can drop the clutch all day long and it doesn't slip and burn.
£285 though..
£285 though..
- moondustka
Yea but that requires a manual adjuster on the footpedal? Also doesn't it make every day driving a nightmare? Im wanting something what will take around 220bhp without having to change pedal really.
- clarks.2007
moondustka :Or there's the 4 paddle from techniclutch. That's pretty amazing. Can drop the clutch all day long and it doesn't slip and burn.
£285 though..
techniclutch's name is absolute mud in Ford circles, would avoid them like the plague. Just type it in a Search on PassionFord and see what comes up.
Where abouts in the country are you?
It really is as simple as picking up a copy of Fast/Performance Ford anc scouring the adverts.
I really can't recomend the AP Racing Organic clutch highly enough though.
The one on deemon tweeks isn't a kit its just the plate Even though its under clutch kit section. I cant get to my fast ford mags because im not at my house. Very stressfull.
- clarks.2007
Re: Best Clutch??
What you think to this?? "stage one clutch : ap racing heavy duty cover with organic plate & bearing s1 + s2 turbo" From this site: http://cosworth.info/store/index.php?ca ... s%20turbo' Should be upto handling 200bhp?? hmmmmmm
- clarks.2007
Re: Best Clutch??
100% do NOT go to techniclucth... they are round the corner from here and have not heard 1 good thing about them ad a few people have used thm... do not go there regardless of the price!!
x
x
- Shell
Re: Best Clutch??
jam2006 :What you think to this?? "stage one clutch : ap racing heavy duty cover with organic plate & bearing s1 + s2 turbo" From this site: http://cosworth.info/store/index.php?ca ... s%20turbo' Should be upto handling 200bhp?? hmmmmmm
That will be fine but do shop around to see if you can get the price lower. I know a few people running about 240bhp with this clutch without slippage. AP seem to really under rate their clutches capabilities (probably to limit warantee claims)
