best sparkplugs?
19 posts • Page 1 of 1
best sparkplugs?
hi guys,as title suggests just wondered what the best spark plugs are to use?.Will be for a 1600 CVH.whats brands are everyone using in their motors?.cheers steve
- PMK3
yeah really its between NGK or champion plugs.was looking at the iridium ones,just wondered if there were any other better ones on the market?
- PMK3
using NGK now too. not been out with them in yet but engine's running much smoother and sounds nicer revved... although that's because the ones i removed were the original plugs by the look of it
- Tweek
- Your car: VW Golf GTD
Bosch Platinum is meant to be good aswell, i had them in my mk2 xr2 when i had it and them seemed good but i never drove car with standard plugs.
- FIESTA_NEO
Oranoco :Standard Ford (PC-08 iirc) about £2.50 each from Ford and work a treat
Now there's a man in the know!
- chumkila
- Dirty Post Whore!
so in your opinion there is no need to deviate from factory standard?.cheers for the replys
- PMK3
It depends what boost you are running as to what plugs to get!
I was running pp8's ok with 14psi but when the boost went up to 20psi they were getting to hot and risked melting so i now have C59's which seem to be ok.
3dr Sierra Cosworth Track car
S1 Escort RS Turbo
- wildheart
wildheart :It depends what boost you are running as to what plugs to get!
I like the way you say "they seem to be ok"
- FIESTA_NEO
he not running any boost mate, N/A
well i had problems with both champion and NGK,
i never had a problem with the standard plugs but i am using bosch super 4's at the moment and they great, cost me bout 20quid mate.
- White2i
I can assure you in the Ford tuning you will gain nothing by running mega expensive plugs in most road going states of tune
Understandable. As I say, I've never gone to town on a Ford engine, only an A-series.
It didn't really improve the power, just a bit more responsiveness mid and top end.
At my father's garage, we only fit genuine Ford plugs in them, and we've had problems in over 20 years.
Well worth it, and they are relatively cheap!
- emoDUDE
- properphatboy
- Your car: Peugeot 306 D L
