Best sports suspension kit for an Si?
16 posts • Page 1 of 1
I'm replacing my suspension for my Si (dampers and springs).
Just wanted to know what sports suspension kit is best suited, i.e what do other people have on their Si 's?
I need to lower the car, but no more than 40mm.
Also, me being naive , what are bushes and would i need to replace them?
At the moment i'm thinking G-Max, but not sure on the quality.
- James_Si
SPAX
Got a spax vsx kit on my Si m8. burton power, 250 quid, absolute bargain and theyve made a hell of a difference. Spax dampers are quite firm and arent nice on bumpy roads but they make up for it in the bends.
- Si16_valve
I am using KYB on my SI, I would recommend them, not so many write ups as not many people have heard of them, due to that they are cheap to buy while they try and get a name for themselves.
- Percy!
- Your car: Citreon
ive had a full gmax kit and now have a full spax kit. THe spax kit is so much better handling on smooth roads but on the bumps its a bit of a c**t and you feel every tiny little bump. The gmax was a good compromise between handling and comfort
- Sunil_FiestaRS_16V
I'm really tempted by the Spax kit for the excellent handling, but not sure i would get used to the rock solid ride.
The G MAX kit is guaranteed for a year more (3), plus it gives a lower drop. And hopefully it'll improve road handling as well. I don't want to take a mini roundabout too fast again and end up going straight foward.
Is it simple to fit yourself? Also would i need to get the wheels re-aligned?
- James_Si
you're need to get the tracking done yes.
i've got the spax kit and its wicked. handles very well for sayin its only a fiesta the ride of firm, but you get used to it. makes the car shake like no other, but if you want it to handle well then you've got to get used to it.
£270 for mine, and i didnt fit them - cuz im lazy
- scotty_boy
The quality of G-Max is dreadful
I can confirm this by haing had one of there kits on for a couple off weeks and the welds broke on the rear suspension cup sending the back of my car to the ground
Very fookin dangerous
Now got Spax and the quality is spot on
3dr Sierra Cosworth Track car
S1 Escort RS Turbo
- wildheart
Cheers for that. I'm gonna get a Spax VSX for the quality.
One other thing; will the front and back sit the same hight?
Only saying this because i know the Si is front heavy. Plus i may stick a 2.0 L in, and that would be even more weight. So would adjustable ride height be preferrable to get the car even?
- James_Si
vsx
with the vsx kit the front sits slightly lower than the back but it looks spot on.
- Si16_valve
Thanks, i'll either go for a Spax VSX, or take a look at adjustable ride height suspension.
One more thing, i know it's been on here hundreds of times but...
15's are the best for the fiesta, performance wise?
16's look better but don't you loose performance and get lots of scrubbage?
How easy is it to modify the arch, can it be done myself?
- James_Si
