best suspension set up
6 posts • Page 1 of 1
hi there just after some advise on what suspension set up to get and best place to get one, am i best to go for coilovers or a spax or koni shock set up, car is lowered 30mm at mo on stanard shocks but will need to uprate them as fitting 17s to car soon.
any advise will be welcomed
steve
steve
- dobbin-fordfreaks
Not too sure on the best setup matey but if your going for 17's then i think you'll be better of with Coilovers as you'll have the option of adjusting your ride height with the 17's whereas if you go springs you won't really know lowering size to get tbh.
Well thats what i would've done anyway but i could be wrong.
Regarding the coilvers i won't know whats the best one or setup to use but ask around as theres quite a few lads on here using different types. See what they recommend
good luck choosing!!!!
- reisskahn
Quite simple - get the best you can afford. As said, coilovers will enable you to adjust the ride height to suit the wheels and make sure you get no scrubbing. People complain that coilovers are too harsh, which is senseless. If they're too stiff, replace the springs, it's very simple. If you can afford coilovers, get them. Avo, FK, Gaz, H&R and Leda are just a few manufacturers available for the Fiesta. I've just ordered a set of Gaz for mine.
thanks for your replys folks. so looks like coilovers then does anyone know if avo ones are any good and where is the best place to get a good deal for some?
steve
steve
- dobbin-fordfreaks
Got GAZ on mine!! Had no probs so far and as said above you make them as stiff as you want them,Dont know how I would of got the perfect ride hight without them on my 3dr rims!! £500 all in I think?!
Drive it like ya stole it!! You'l never see rust go so fast
- Liams
