Big Brakes
20 posts • Page 1 of 1
Big Brakes
jst bort brake set up off st24 and im gonna fit em on satday.
now, before i start to fit em (pmt em) has any1 done this in the past and found any probs?? as in, will i have to make a bracket, or will they bolt str8 on? (i could see the bolts bein smaller on the fiesta but im hopin there not )
simple q. simple answer pls.
"Put your hands up mother stickers, this is a f**k up!"
- Pop
They are the same as the Mondeo V6 calipers so what you need to do is have the backs machined so they fit the mounting bracket, and drill the holes slightly bigger to accept the bigger bolt size.
Once done they fit straight on and make a big improvement in braking power
- Stoned
drill which holes bigger???
not on the hub [ERRR] wot they gonna thread into?(unless u get em rethreaded)
machine, as in take sum off? u speakin from experiece here?
yeah they are the same. st24 is jst v6 [ERRR] bumpers and a badge.
- Pop
The threads r on the calipers, not the hubs. You need to drill out the hub holes from 10 to 12 mm (as stated b4, no threads there) and you either need to have the caliper back machined so it sits 3 to 4 mm further in or get a spacer plate to bring out the discs for a similar amount.
Goncalo D.
Goncalo D.
- voorhas
- Location: Portugal... and no, that isn't a Spanish city
what they are trying to say.., in plain english...., if ya dont machine the caliper mounting bracket so it sits further back into the hub then the brake disc will faul the caliper bracket upon fitting and the hub will not turn. not nice
- 285Andy
- Your car: fiesta rs turbo
285Andy :what they are trying to say.., in plain english...., if ya dont machine the caliper mounting bracket so it sits further back into the hub then the brake disc will faul the caliper bracket upon fitting and the hub will not turn. not nice
thank god.
u also give a "no nonsense" answer lol.
got it now. rite. thats a bit of a blag but no prob. il js get em lathed 2moz once iv measured how much i need to take off.
my wheels rub on my body kit already so if i space the discs out that means my wheels will rub even more!!!! damn.
- Pop
Dont patronise me stoned person.
I do hav a little knowledge, but its hard to know wot ur lookin 4 before u even look (obviously)
well, iv looked 2day and seen that i cant space my discs [ERRR] my tyres will foull my bodywork.
i have use of a lathe and a millin machine but dont wanna fook up, so i think i will pay sumone to do it. mite aswell. then i can blame them for wonky wearing! anybody recommend someone who can do it?
who did urs mr stoned?
ps, y dint u fit cossie brakes?
- Pop
I Fitted mine by making up a steel spacers which fiffed in behind the discs, but i had all this planned and bought the correct offset wheels to fit correctly...
i didnt like the ideal of machining the hub tbh
- unknown_user
i wud do that but, [ERRR] my car is low, it will scrub even more!!!! they are the right offset.lol.
u dont have to machine ur hubs, jst the bit where ur caliper bolts onto the hub (on the caliper). its only bout 3 mm. i jst dont wanna do it and then be gutted wen iv not got optimum braking [ERRR] i didnt do it properly!!
- Pop
erm, no im not. wots with the interrogation?
i got my answer yes thankyou, now im stuck i need to know if anyone can do the fitting of them 4 me.
do u know? if not pls dont make me look like an idoit in my post where im jst tryin to get sum brakes on ma car. thanx
- Pop
Yeah you machine about 3mm off the caliper. I didnt use Cossie items cos they are about 12 years old at the minimum and spacing them out with washers is a bodge job
Plus I got mine of gadget for £150 brand new and pre-machined inc pads and discs. Pads are cheaper and disks are dead easy to get. Bargain
You will find your pedal has a lot more travel after fitting them however
- Stoned
Gadget would've had them machined professionally. I will vouch for that. Can't go wrong with someone who works at Dunton!
- chumkila
- Dirty Post Whore!
