BIG brakes which ones
11 posts • Page 1 of 1
i need bigger brakes i want the cheapest but the best money range 200-300
can ne1 help?
i bought a fiesta rs turbo by the way so it has to fit on a mk3 and dont worry about rim size im getting some 16s
can ne1 help?
- SEG1
Then only one's you will get for that price is cossy 4X4 or st24 or st150 Unless you find some one selling off there wilwoods new there £460 +£80 for the pads
- j7aoc
Cossie 4x4 discs are £150 for anything worth having and the pads are £60 for something respectable, don't leave much in the kitty for the calipers but it can be done. Work superbly well:Q
- properphatboy
- Your car: Peugeot 306 D L
rs2000 is 260 mm disks actually.
but the callipers are harder to find.
i think erst ones are the same, work much beter than standard with xr3i mk5 disks.
but youl find yourself wishing you got cossie ones.
- Jonezy
jimmyesh :ST170 300MM conversion, best value in my humble opinion!
300m dats nice!!
do the backs and fronts fit??
are they easy to fit!
- SEG1
FORD-4-LIFE :will the 300mm discs fit inside a set of 15" rims ????
NOPE!! but they fit perfect behind 16"s and look the nuts! See my RS1800-st170 conversion thread in member's gallery. REALLY easy to fit too - the calipers just bolt straight up to the fiesta hub-carrier (once you've drilled the holes out to 12mm)
280mm ST170 rear brakes go on a treat too but you are best off using a zetec s rear beam and living with your wheels sticking out a bit further due to the wider focus hubs... or just modify a mk3 beam PROPERLY AND SAFELY as i did
- jimmyesh
- Your car: Yes
i got my 4x4 cossie ones for £200 that was with all calipers rebuilt with new seals etc and new pads with discs that had about 1000 miles on them not a bad deal really i have had them on the car for 10k and they havent missed a beat
dont hate the playa hate the game
- si 16valver
