Black Top Zetec
11 posts • Page 1 of 1
Black Top Zetec
Anyone know the spec on a 'Black Top Zetec' ?
Anyone got any idea bout fittin one in an XR3i ?
- Low Down And Dirty
- Location: Andover ish Drives: RS1800 and Overfinched Range Rover
Effectively the same as the metal top 90ps 1600, and 105/115/130ps 1800 and 136ps 2.0L engines, but the engine and alternator mountings are significantly different.
More information at http://www.fiestaprojects.com
Al
Al
- Project
- fiftyoneCL
Project ST2000 :Effectively the same as the metal top 90ps 1600, and 105/115/130ps 1800 and 136ps 2.0L engines, but the engine and alternator mountings are significantly different.
Al
The zetec-r is metal too Al just a lightweight magnesium alloy.
No real advantage to fitting the black top mate, except a bit more refinement.
- Phil Si
Car: 2000 BMW 330 Ci
Phil Si :so its not a plastic cam cover then lol i always thought it was odd that it was plastic
me too
My Bad!
Sorry
Sorry
- Fiestasi-Andy
As far as I can tell, the black-top cover is significantly higher than the shiny-tops and I doubt the crossover charge pipe would fit under the bonnet.
Cam belt cover is different shape to match it.
- Project
- fiftyoneCL
Project ST2000 :As far as I can tell, the black-top cover is significantly higher than the shiny-tops and I doubt the crossover charge pipe would fit under the bonnet.
It may work mate - there are 2 heights to the cam covers - the higher one is usually the 9:1 compression engine and the low one is the UK 10.5:1
The Higher cover can also be the 10.5:! but is usually on the VCT engine.
Your right though because the zetec-e has a cut out at the back for the crossover pipe dosent it...
thought i read somewhere that the two could be changed over? if this is te case couldnt u put a shiny top one on the Zetec R?
- Phil Si
- Phil Si
