Bleed Valve Fitting
Bleed Valve Fitting
Postby R0BBY on Wed May 02, 2007 7:32 pm
HI
can someone tell me how to fit a bleed valve to a frst?
Rob
R0BBY
Postby Oranoco on Wed May 02, 2007 7:37 pm
If you are having to ask how to do it you shouldn't be doing it yourself. Upping the boost pressure without ensuring the fueling is correct WILL end in expensive tears due to something like this.
Oranoco
Postby R0BBY on Wed May 02, 2007 7:39 pm
Hi
thanks for that, so should i get it chipped b4 a fit the bleed valve?
Rob
R0BBY
Postby Oranoco on Wed May 02, 2007 7:45 pm
Don't need it chipped but you will need to ensure there is fuel to match the increase in boost. I'm not overly sure where the standard boost cut is (about 10psi iirc). You may as well get a 165 chip and have it set up by a reputable tuner to ensure nothing goes pop on you.
Oranoco
Postby Fezzy Turbo on Thu May 03, 2007 10:15 am
Oranoco :
OUCH!!! :aaah:
2009 FRS2 : 377bhp ATW / 395lb/ft :)
1990 FRST : Sold.
Fezzy Turbo
Tartan Turbo Terror
Tartan Turbo Terror
Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
Postby R0BBY on Thu May 03, 2007 1:23 pm
Would a power boost valve not give the engine the extra fuel for the increased boost?
Rob
R0BBY
Postby Oranoco on Thu May 03, 2007 3:10 pm
Power Boost valve is one of the biggest cons going. The standard Ford item is fully adjustable and up to everything you will ever want to throw at it.
Oranoco
Postby R0BBY on Thu May 03, 2007 4:04 pm
So how do you find the standard ford one and how do you adjust it?
Thanks For Your Help
Rob
R0BBY
Postby mrorange2 on Thu May 03, 2007 4:15 pm
as above mate get a tuner to do it for you the standard ford on is on the end of the fuel rail and IMO 100% better than an FSE boost valve.
2014 Fiesta ST3 & Mk6 Fez ST
mrorange2
Postby Oranoco on Thu May 03, 2007 6:12 pm
R0BBY :So how do you find the standard ford one and how do you adjust it?
Rob
YOU don't do it. I'm pretty sure you don't know what you are doing as you don't know where it is and most people don't have a wideband lambda to check fueling while the engine is under proper load.
I'm not trying to be funny with you just trying to save you a lot of money when things go wrong. Most tuners are pretty happy to let you watch so you can learn about what's going on
Oranoco
Postby R0BBY on Fri May 04, 2007 9:06 am
Hi
i know you not being funny, i appriciate all ur help, i will wait till ive got some money and get a tuner to do it for me,
Rob
R0BBY
