Bleed Valves + Fuelling
7 posts • Page 1 of 1
i've just now fitted a bleed valve under me bonnet which is boosting to 10psi then holding at about 8.
i've read a few posts about fuelling having to be set up on the rollers to stop evrything going Pete Tong . is this right? its got a full Mongoose and Filter and i have read that the engine management sorts all the air/fuel ratio out anyway. who's right??
Cheers Guys
T2
Cheers Guys
T2
"What's the reasons?"I'm a pimp in every sense of the word, bitchBetter trust than believe em
- T2
yeah u defo need to get fueling set up on the rollers u know any good RR places in sheffeild? as its just down the road from me
- Phil Si
Car: 2000 BMW 330 Ci
they are such a good place!
went to the rolling road thingy there, they did a speed test on pauls car for free, and he put my car ont he rollers again at the end for a free run to see if it was my air filter that was causing probs, but it wouldnt stay on the rollers lol, at least he tryed
- Phil Si
one of the customers who come in my shop said it is his brother who runs it. so i'm hoping for a cheaper run . i've read some of the old posts and there has been alot of bickering about Bleed Valves and Actuators so i think i'm going to adjust the Actuator so that i'm not fooling the ECU and running weak!!
i'll have it set up as well to make sure everything is sweet though.
T2
T2
- T2
It doesnt matter if you use a bleedvalve or actuator you will still need to get the fuelling set-up.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
