bolt on
7 posts • Page 1 of 1
you need to lower compression to run a turbo, and on a 2.0 you can run a decompression plate so u need low comp pistons, and to sort out oil breathers i think it is mate. have a look at streetdragsters post if you feel up to doing it ureself!
- Rhinopower
- Your car: Volvo FH330
Rhinopower :you need to lower compression to run a turbo, and on a 2.0 you can run a decompression plate so u need low comp pistons, and to sort out oil breathers i think it is mate. have a look at streetdragsters post if you feel up to doing it ureself!
dont think you have got that right there mate.
you can use a decompression plate to lower the CR or you can use low comp pistons (much better way) athough it is more expenisve to buy stronger pistons, but you can run more boost for more power in the future. You could use a deompression plate quite happy on low boost and be fine, athough you will still have to change engine managment, cooling etc.
Either way it isnt just a "bolt on" mod, you will need to change a of things and depending on how much bhp your after can get very expensive!
- Nick 2i
no, u can use a decomp on a 1.8, and on a 2.0 but the 2.0 wont last very long, percy! has brought up the question before and it shouldnt be done
- Rhinopower
u can turbo nething!!!! but without internal change and fuel changes wouldn't like to see how long it lasts
- MAD_Adamski
