boost limit
2 posts • Page 1 of 1
boost limit
hello!i´m from germany and have a 2,0 zetec turbo.i´ve lowered the compression with a plate of 2,0 mm.it´s 8,5:1 cr.
my question:
with how much boost can i drive to have no fear of detornation?
at the moment i drive with the originale ecu 130hp.@4bar fuelpressure.
i´ve got a 5th injector wich i put it by 5psi into.is this correct or drive it to lean?
i hope you can help me
my question:
- alti
urm detonation aint really your prob, if your running standard pistons this will be the limits of how much boost u can run, not alot lol. u can put how much fuel u want into it, u still aint got forged pistons that are designed to run with high pressures and heat that a turbo engine gives out
nearly 60psi fuel pressure, bit high innit lol, as your running a standard ecu, don`t expect it to last long as fueling will be way out. u need a mapable chip with ofab(turbo ecu) or aftermarket management.
- snake
- Trainee Burger Flipper
- Your car: ford
