Boost Pipe - where dump valve sits
Postby JJ on Tue Sep 05, 2000 1:17 am
I have a spare std one too.
JJ
Postby Andy on Tue Sep 05, 2000 3:35 am
yeah there the ones. i got mine cut and had a dump valve put in to see what they are like, but i lost 5psi and was blaming it on the leaky non piston type dump valve so want the hose to be able to put it back to normal. since then though been told that DV wont leak that much air, and more likely to be due to accident causing actuator boost pipe/bracket to have bent. maybe this is why im only boosting 10psi at the mo and dump valve not as loud as expected. <IMG SRC="http://www.rs-turbo.co.uk/ubb/smilies/confused.gif"><br><br>Ade, i need a bonnet for mine and noticed you had enquired bout one on the RSOC chat board. You get it? got one? know of one?
Postby Andy on Tue Sep 05, 2000 9:29 am
anyone got one?
Postby Adrian on Tue Sep 05, 2000 12:04 pm
I've got Samcos now, so I have a complete set of original hoses.<br><br>Is it the one that goes from the intercooler to the "TURBO" charge carrier pipe?<br><br>I can bring it to Trax if you want.<br><br>Adrian.
Adrian
