Boost, power, intercooler
10 posts • Page 1 of 1
Hi all, ive got my Uprated fuel pump and beige injectors, hybrid T2 and scorpion exhaust and k&n 57i, uni-chip etc....
I was running 15psi, it was fine, had it set to 18psi, standard intercooler, NO chargecooler and it was holding back something cronic...
So its back down to 15psi again
If i got a charge cooler, will that allow me to get the power i want and 18/19psi like i had.. without it holding back??
Ian
Ian
- Ian C70T5
- Das Ist Kapput
Definatley, the car is holding back because the fuel is not getting a good burn as the inlet air temprature is too hot. Stick a chargecooler on and it'll got like fuk!!!
- TURBOJUNKIE
have u tried super unleaded. dnt thk i wll help but its worth a try
- fiesta_fras
- Elite Poser
Nope, have not done anything yet. will do soon, but i want to get my charge cooooooler and then i'll invest in a cam, with the old low comp pistons and anything else a find i need etc...
I have tried super, does make it go quicker and better mpg, but still holding back, this hot weather dont help either...
- Ian C70T5
- Das Ist Kapput
18psi with standard i/c
Calm down lad you do need to get a chargecooler or at least a Pace i/c and as Bassboy said, you need to get the bottom end sorted.
What about your gearbox ??????
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
As my car is standard engine wise, i'm not really sure about modding the engine..
you say about getting the bottom end sorted - correct me if i'm wrong but doesn't a normal stage 1 chip raise the boost upto about 14 psi.. so do you need to get the bottom end strenghtened wity just a chip then?.. i thought you just got the chip set up with new actuator and off you go
My mates FRST.. and it is my mates not mine has been chipped and his peaks at 15psi with no bottom end mods.. is this bad then? i thought everyone did this ?
Cheers - a totally confused dumb ass
Mark.
Mark.
- MarkFRST
Mark,
My car peaks at 15psi and i have had minor bottom end work done :-
New crank shaft oil seal. But apart from that nothing else.
I have had the head off my engine and the bore, pistons etc.. were checked and looked lovely
I have had all the bearings and oil seal changed on my gearbox, due to an oil leak onto my clutch caused by the main bearing falling to pieces and knackering the oil seal.
Just make sure you have a new, up-graded head gasket and good compression etc... and it should be ok, BUT if you drive with a right foot made of lead any engine will let go no matter what you do.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
cheers Fezzy Turbo.. i've lean't some new stuff today..
i'm not planning to chip my engine, standard is beautiful...and no explosions should happen.
I'm happy how my car is! and i don't drive with a heavy right foot.. i just enjoy driving her safely.
Mark.
Mark.
- MarkFRST
