BOOST.
11 posts • Page 1 of 1
BOOST.
How much boost do you run in your cars and to what spec???
I'm really getting bored of standard boost .
Mine runs 7psi dropping to 6psi and produced 159.7bhp at the last road tune.
- Brammer
- Your car: Sierra Cosworth
Why have mods moved this to here as this is a question asking people what boost they run in their cars and to what spec not a tech question, can you move back?
- Brammer
Sorry mate. I would consider a question about the amount of boost being run in a car and to what specification as indeed being a technical question, and not something that qualifies as general car discussion. However, I will bump it over to tuning for you, as in fairness that's probably more appropriate than having it in here.
- Capri
- Your car: 1989 Citroen BX GTi 16v
Re: BOOST.
h196jne :How much boost do you run in your cars and to what spec???
is that standard frst boost?
what other engine mods do you have?
- paradox
imo it looks like its making good power on low boost so id leave it as that personely.
But.... mine T2 hybrid runs 16 psi, and my spec is as follows:
195 chip
beige injectors
cossie pump
grs fmic
k&n, Mongoose exhaust.
195 chip
beige injectors
cossie pump
grs fmic
- MarkRS2K
Re: BOOST.
paradox :is that standard frst boost? what other engine mods do you have?
Fully worked head (jamsport) matched
kent cvh36 kit / vernier
Universal turbo's hybrid stage 1 T3
Cossie cone
mongoose full system + stainless downpipe.
this week fit my pro-alloy front mount.
Mark did your do 200 @ fast ford RR shoot out???
- Brammer
Ahmed Bayjoo 195 Chip
T28 Hybrid Turbo with 360 bearings and cut back blades
AP Paddle Clutch
K&N
Mongoose system
Beige Injectors
LSD Gearbox
Custom one-off Radtec Intercooler and Rad
I only got as much as 170 on the rolling road due to the clutch slipping and was running about 12psi
I am going to replace the clutch and go back to see what I get. WIll probably raise the boost to 1bar
AP Paddle Clutch
K&N
Mongoose system
Beige Injectors
LSD Gearbox
- Superal
- Location: Waltham Abbey, Essex Drives: Peugeot 206 Work Van
m4frd : the bhp has ranged from 195- 206 and the torque between 189- 212.
Great figures for the spec
- Brammer
