boost!
6 posts • Page 1 of 1
nething u want wats been done to the bottom end, turbo, compression ratio and [ERRR] chip r u using?
if all above r standard then dont run more than 10psi maybe 12psi but u might get detonation...so its ur own risk!!
bassboy
bassboy
- bassboy
- Authorised Trader
Personaly wouldn't touch the bleed valve unless on a rolling road with a very good air/fuel ratio meter and also very good boost gauge. If not you will next be posting in the 'Parts Wanted' for a FRST engine
- nthorpey
Absolutely - if you don't increase fuelling to match boost, even without detting you will overheat the engine, especially components such as cylinder head, valves and valve seats, and could even crack a piston.
Don't fiddle with it - there's no such thing as free power.
- Project
- fiftyoneCL
If you want to run more than 10psi you will need a chip to remove the overboost protection.
If you have a bleedvalve you do NOT need an uprated actuator.
Max boost on std fuelling is around 14psi and that is plenty for the std intercooler to take as well.
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
