braided hoses from master cylinder to calipers!
Postby xrsi on Thu Jun 03, 2004 11:51 pm
right i am wanting to do this at some point very soon!
i know mark (excursion) did this, but i was wandering how you did it, the bias valves are fixed so you cant turn them, and also the master cylinder is fixed so you cant turn that! so how do you fit them so they dont kink!
also how far did you go with one tube? did you do all the length in one or split it into sections? also what sort of conectors did you use?
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby dannyboy on Fri Jun 04, 2004 10:44 pm
I will be doing this at some point, everything you need is available from Think Automotive, give em a ring and they can tell you what you need, ive made a list but cant find it at the mo.
dannyboy
Postby xrsi on Sat Jun 05, 2004 6:53 pm
getting the stuff aint a prob... its just did you use diff bias valves as the ford ones wont turn round so would kink the hoses!
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
Postby phatboy on Sun Jun 06, 2004 12:19 am
could you not do one end up tight, and count how many turns u did, undo it again, do up other end, and then twist the hose the opposite way to it kinked the amount of times u turned it to do it up, then do it up, ending up with it straight?!
thats my idea, lol! Mite be stupid, but i tried!
phatboy
Postby Excursion on Sun Jun 06, 2004 2:03 am
male/male from bias valve and finish the hose with a female swivel, if you read up you can figure all this stuff out :)
Postby xrsi on Mon Jun 07, 2004 11:11 am
thats the sort of answer i wanted mate ;)
will go to demon tweeks and pester them ;)
thanks :D
xrsi
XR(ustyAtTheMo)SI
XR(ustyAtTheMo)SI
