brake advice
2 posts • Page 1 of 1
brake advice
caliper - brembo 4 pot
wheels - escort cosworth
whats the biggest disc i can use?
300mm st170? or is the caliper too big??
if 300 is too big with that caliper
my next biggest option would be esc cossie discs @ 278mm????
- RS rob
If your putting the wheels on your Fiesta you will be far better off fitting the Mondeo rims as the Escort Cos uses an ET25 offset which is too much and will affect things for the worse.
4x4 Cossie brakes are tried and tested and will stop the car on it's nose and will also hide nicely behind a 15" rim (the best for handling on the Mk3) The ST170 setup will go behind a 16" rim and works very well. I've had no probs with the ST170 setup on my track car
