Brake cylinder question
9 posts • Page 1 of 1
I was just going to buy a new brake cylinder for my Escort servo.
BurtonPower has 3 options
RD300 MASTER CYLINDER .625in 7/16 UNF INLET. 3/8 UNF OUTLET
RD300B MASTER CYLINDER .700in 7/16 UNF INLET. 3/8 UNF OUTLET
RD300A MASTER CYLINDER .750in 7/16 UNF INLET. 3/8 UNF OUTLET
Clearly the only difference is the bore size value?
Am I right in thinking getting the biggest size possible (.750) would result in better braking force for my setup, due to being able to push more liquid?
I have discs all round and a Fiesta brake cylinder was useless so I'm looking to get as good a model as possible.
What's the deal!
What's the deal!
- Stoned
Always a bit of a headfcuk this kind of question! lol
Pressure = Force / Area
So if you reduce the cross-sectional area (or reduce the bore of the master cylinder in other words) then the force applied needs to be smaller to get the same pressure. So if you get a wider bore, you'll need to apply more force to retain the same pressure in the system.
As I say, this is one that fries the brain a bit, but I think I'm right in what I say
does that help chris?!
I think thats right....
Say a pipe is 10mm wide, and another is 20mm wide.
If you pushed brake fluid (just imagine!) down them, the 10mm one would have more pressure at the end when the same force is used.
- PaulC
So I suppose to finish the question off...
The large bore would make for a more sensitive feel I guess, (in a similar way to PAS and normal steering) and the small bore would be lighter on the thighs
How about a compromise and go half way? Ok sensitivity and not too tiring Shame you can't try them all and see which feels best really.
Well as it turns out their website is wrong. The cylinders they list there are only for ancient single piston Escorts/Capri's so none of them apply
A genuine brake cylinder is now being sourced from a local motorfactors.
- Stoned
