brake discs
16 posts • Page 1 of 1
brake discs
i am after some drilled and grooved discs but the drilled.hole has to go all the way throught does anyone know where i can get them from
or are just drilled and grooved discs that hole does not go all the way throught are the ok .. what do u think
thanks
thanks
- boardster
grooved discs and a set of ferodo ds2500 should improve yer braking if thats what ur after
- Priezti
what car they going onto? ive just ordered a set of grooved discs off ebay for £50 posted, and got some new ferodo pads for them, should be a slight difference in braking, mine are going on my fez si.
:: blade ::
:: blade ::
- :: blade ::
Drilled discs aren't really suitable on a road car as they holes cause cause cracking. Not really an issue on a track car.
4x4 Cossie kit works very well. In all honesty I doubt very much you will need anything more than good quality standard discs and a good set of pads like Mintex or Ferrodo DS2000 (iirc).
If you must put something posher in I can highly recomend Tarox 12 groove discs.
No need for this fancy discs most of the time.
I use standard discs along with good brake fluid and race pads on track and never have fade.
So imo get standard discs,fresh fluid and good quality pads
3dr Sierra Cosworth Track car
S1 Escort RS Turbo
- wildheart
wildheart :No need for this fancy discs most of the time.
Whenever you post I could swear I've got an echo
