Brake Pipe Question
9 posts • Page 1 of 1
Brake Pipe Question
I'm about to order some new brake lines to remove my ABS i just wondered if people knew what unions i needed and what type of flares domed or cupped?
2014 Fiesta ST3 & Mk6 Fez ST
- mrorange2
you gotta work out how many male and how many felmale connections your gunna need.
i would get to scrappy, get the whole lines, or cut a load of connections off.
all the threads are the same though
My Local charges me 20p a fitting and everytime I need some I buy ten or so of each and then I have a few in stock
Just go buy 10 normal males, 10 normal females, and five long males, a length of copper of steel brake line and a brake flaring kit. You'll be able to do the entire job with that.. guaranteed
Formerly Jay246
- Jay
Car: 1992 Ford Fiesta RS 1800
Buy new ones - don't be a PIKEY!!
Rally design stock all you need male and female - I got a pipe cutting and flaring kit from ebay and a 25 ft roll of copper brake piping when I re-lined my car. Didn't cost much at all and you have the peace of mind that you have all new lines
- jimmyesh
- Your car: Yes
As above, don't do it Jay-style Brake fittings cost pence from motor factors, and they should have a coil of brake pipe too, also cheap. Brake pipe flaring kits can be bought for under £10 posted, spend £15-£20ish to get an acceptable one. You need M10 x 1mm fittings, male and female. The pipe flaring kit will include a pipe cutting tool.
fuuuuuuuuuuuuuuuck off
mototr factors never had any in stock when i asked about then so had to go to scrappy, turned out i never needed them anyway, good job they never cost me anything
