Brake upgrades
7 posts • Page 1 of 1
Brake upgrades
Can someone suggest a brake upgrade that will go under 14" rims please
- P-reg-Turbo
- Your car: P Reg Fiesta RS Turbo
Re: Brake upgrades
I use Series 2 Escort Turbo calipers with MK5 ZS discs. I was using MK5 RS2000 discs, but they're a lot more expensive! The ZS ones are 2mm thinner, but work fine. You can use the entire ZS setup if you like, the pistons are slightly smaller so will probably give a slightly better pedal, but with marginally less braking power. I have a feeling the 260mm MK6 Fiesta brakes will fit straight on, but I haven't looked into yet - I believe the brake discs are the same as the 260mm MK5 and Puma ones. The complete MK5/6 RS2000 and 130PS XR3i brake setups will also fit. There's probably more, but all should fit under 14" MK3 Fiesta wheels without issue
- Smo
Re: Brake upgrades
Brake upgrade fit a bigger and better servo
- mikeymikeyp
Re: Brake upgrades
Thanx SMO, will got with S2 calipers and ZS discs, are these the discs i want?? http://www.ebay.co.uk/itm/Fiesta-mk5-1- ... 45eeb0f78c
Mikey ive done the mondeo servo upgrade already
- P-reg-Turbo
Re: Brake upgrades
Can you give more details on the brake servo upgrade please?
What Mondeo?
Fitting advise?
Other parts needed?
Comparability/uses etc?
Cheers Chris
What Mondeo?
Fitting advise?
Other parts needed?
Cheers Chris
- s1chris
Re: Brake upgrades
s1chris :Can you give more details on the brake servo upgrade please?
What Mondeo?
Fitting advise?
Other parts needed?
Cheers Chris
Follow this link Chris
http://www.fiestaguides.co.uk/content/m ... inder.html
- P-reg-Turbo
Re: Brake upgrades
P-reg-Turbo :s1chris :Can you give more details on the brake servo upgrade please?
What Mondeo?
Fitting advise?
Other parts needed?
Cheers Chris
Spot on, thanks. Clear which direction I'm going now.
Cheers Chris
- s1chris
