brakes
17 posts • Page 1 of 1
ive got some 4x4 sierra cosworth discs and calipers with mint pads for sale 200 quid the lot am located M1 JNC 33/36 if your interested
dont hate the playa hate the game
- si 16valver
ERST Calipers fitted my WIP 2.0 Si... only bolted on ATM, haven't connected hydraulics (Car is OTR )... so can't comment on performance!
Should be OK ERST Piston diameter 59mm, 1.6Si 53mm.
ERST calipers are same as Sierra XR4x4
(the 2 litre twin cam NOT Cossy)
Bolt on swap... along with Mk5 130bhp XR3 260x24mm discs.
Calipers are approx 0.5/1.0mm off central over the disc which is good enough.
Useful info here: http://www.brakeparts.co.uk/
- Reckless Rat
nice! o yeah finally they came thriough the post and need a bit of a clean. wire brush and brake cleaner ent workin. any easy ideas? also one of the wirey bracket things is missing. where casn i get another.
- Jonezy
Jonezy :should the disks that came with the callipers be 260mm.
Mine are 260mm (pictured in the post above)
For seals, service kit etc open the online cat here: http://www.brakeparts.co.uk/
When you found the calipers pick 'associated parts'
there's all sorts of service kits available!
Dunno if they're better priec than Ford though!
RR
- Reckless Rat
got em on fitted and working. works little better than my standard brakes and have got no pedal feel what so ever, the pedal is also spongey as F**k, will fitting a better master cylinder, servo any thin sort this. am halfway through bleeding the whole system and putting new fluid in.
- Jonezy
