brakes?
10 posts • Page 1 of 1
brakes?
the standard brakes are $hit on my frst. and the abs feels like its cutting in to early and feels like u could stop better with out it at times, but what the best up grade to go for pads, pads & discs etc and do drilled disks make much difrence or is it better changing calipers etc.
cheers si
cheers si
- sihart-frst
EBC discs are very good...as are black diamond discs....pads wise, EBC are pretty good, as are AP Racing (even their normal range), Mintex, Pagid fast road...theres loads out there! just depends on ur budget
drilled discs do make a SLIGHT difference but i dont think ud be able to notice to be honest...they just cool the discs as air moves through them.
bassboy
P.S, change ur discs and pads to see how u get along first
bassboy
- bassboy
- Authorised Trader
cheers for that bit of advise but thinking of selling car at mo so will hold fire at mo
cheers anway si
cheers anway si
- sihart-frst
i have 4x4 cossie setup up the front and RS2k rear disks to go on!
mostly for the looks more than the stopping power
get some goodridge braded brake hoses i find they make a bit of difference !
if stopping is what u want get cossie 4x4 disks and calipers !
278mm disks i think so will need 15" wheels or bigger. I
payed £160 with some slightly used grooved disks from North London RS centre
- MadcatCraig
- BANNED SELLER
do the cossie calipers bolt strait on or do u need spacers? if so where can u get spacers from.
cgeers si
cgeers si
- sihart-frst
cherrs might try pulling the fuse and see how much difrence it makes first as the cars totaly standard and dont realy want to mess 2 much as might cause probs when i sell it cheers any way si
- sihart-frst
