[ERRR] brakes!
6 posts • Page 1 of 1
[ERRR] brakes!
Im getting my 2L engine put in wednesday all going well... now i need summink stop it!! [ERRR] brakes fit! i want best but i aint spending stupid money! i have 15 inch venoms!!!!!!!!! no venom jokes plz
- unknown_user
If you're really serious about stopping your car then probably the most effective upgrade for you is to use cossie 4wd callipers and discs, as the entire upgrade should cost around £250. Check else where in this forum for more info, but they should fit under 15s.
Failing that find some good pads, matched to Ford OEM discs. I would recommend Pagid pads, but advoid Green Stuff.
Regards,
Stephen
Regards,
Stephen
- Quantum
What's wrong with 15s ??
They give great comfort.. and even enough sticking power (if the right tires are fitted ... like Bridgestone RE720s)
- Jur
i can truely say that ht ecozzie optin s the best to go for, and the cheapest for a big break set up!!
- xrsi
- XR(ustyAtTheMo)SI
Looks like ill have to do that then!!!!!!!!! when i have some money! unless any1 wants to pay for them?
- unknown_user
