bridging power on amps? : Insurance | Fiesta Forums
Postby ukgaz on Tue May 01, 2007 2:39 pm
can this be done by putting a wire between the two amps? ive got two 600w amps, if i wanted to add the second can i link of a cable from my primary to the secndary? plus im guessing ill need a new amp cabling set since mines only 720w max
ukgaz
Postby dontpannic on Tue May 01, 2007 2:59 pm
Can I bump this as I need to know the answer to this too...?
Postby ukgaz on Tue May 01, 2007 4:45 pm
please do i want to get mine setup by the weekend as im going to a meet :D
ukgaz
Postby properphatboy on Tue May 01, 2007 5:02 pm
What's the fuses in each of the amps? This will determine the amount of current your wires will need to be capable of handling. The correct way to do it would be to get a distribution block, and run wire from the battery to this, then from this to the 2 amps.
properphatboy
Your car: Peugeot 306 D L
Postby ukgaz on Tue May 01, 2007 6:27 pm
both fuses are 30amps
wiring fuse is a 60amp
ukgaz
Postby properphatboy on Tue May 01, 2007 7:54 pm
Your amps are 600W Max then, not RMS.
30x12=720W
Your power wires should be fine, as long as they're rated right. I'd probably go up though, just to be uber safe, but that's just me.
properphatboy
Postby ukgaz on Tue May 01, 2007 8:46 pm
ive just bought one of those distritubion boxes with two 40amp fuses so hopefully that should hold it nicely
ukgaz
Postby HCS PIMP on Tue May 01, 2007 9:34 pm
if i were you get a 1.3 farad cap from a site i found only £50 will save blowing amps, speakers and ear drums as i learnt to my cost muahahahhaha owwww 2000w watts in one big thump = means 2 dead speakers and no balance i pulled over and felt out of my car due to the disorientation ahhhhhhhhh
HCS PIMP
if i were you get a 1.2 farad cap from a site i found only £50 will save blowing amps, speakers and ear drums as i learnt to my cost muahahahhaha owwww 2000w watts in one big thump = means 2 dead speakers and no balance i pulled over and felt out of my car due to the disorientation ahhhhhhhhh
HCS PIMP
HCS PIMP
Postby properphatboy on Tue May 01, 2007 10:38 pm
HCS PIMP :if i were you get a 1.2 farad cap from a site i found only £50 will save blowing amps, speakers and ear drums as i learnt to my cost muahahahhaha owwww 2000w watts in one big thump = means 2 dead speakers and no balance i pulled over and felt out of my car due to the disorientation ahhhhhhhhh
Eh? :-?
Don't quite understand that one.
properphatboy
Postby ukgaz on Wed May 02, 2007 7:54 am
i tested my setup today and worked fine, its done as follows for the other bloke who was asking
battery -> fuse -> power distribution box with two fuses ->
connector 1 -> amp1 power conn
connector 2 -> amp2 power conn
if it sounds confusing add me on msn and ill help you
ukgaz
Postby dontpannic on Wed May 02, 2007 5:43 pm
properphatboy :
Eh? :-?
I think he meant that he turned on his system at full whack blew two speakers with 2000W and juddered his inner ear bones which control balance of the body... :-?
If that is how I read it that is f*cking hilarious :D
ukgaz, thanks for that mate, I'll give that a go when I get my other amp!
Nick
Postby Jonezy on Thu May 03, 2007 1:19 pm
use one of the other channels for your distribution block and one of the lives can be used for a boot neon :)
Jonezy
Postby ukgaz on Thu May 03, 2007 2:03 pm
now thats a good plan, i was looking at using some blue ones, but the only ones i can find are ones that connect into the cigerette lighter, got some linkys mate that i could get some ones from that could be cabled onto the distributor
ukgaz
Postby Jonezy on Thu May 03, 2007 3:01 pm
use computer cold cathode tubes. much cheaper.
just type cold cathode in ebay and look for blue 12" tubes then.
they should cost around £7
then go to motor world and get a telescopic boot switch (black platic)
use the switch on the earth side.
use an inline fuse holder with a wire from your dist block as the live to the lights. stick the lights to the bottom of the parcel shelf , use the inverter you get with the tubes and lamp em up.
Jonezy
Postby dontpannic on Thu May 03, 2007 8:02 pm
Jonezy :use computer cold cathode tubes. much cheaper.
NOO!
Dont' buy them from ebay - go to ebuyer.co.uk and get them for £2.00!
Theres my guide to footwell neons in the Guides section with links!
Postby ukgaz on Thu May 03, 2007 9:31 pm
hey i got one of those sets from my pc already lol dont use them any more so might aswell
ok cabling on this goes
lights > some black box which the two lights connect to > two cables (black, from what i read is the ground and a red)
the red one has a switch in it so im guessing thats what goes to the distbox and black to ground of course
would it be ok to join this onto one of the spots from where the amp is connected to on the dist box?
ukgaz
