Build a stealth shelf
Postby Championboi on Fri Dec 14, 2007 12:51 am
Hey guys
i am going to be changing my system around abit and wanted 2 no wot is the best way of going about a stealth shelf? the shelf has got to be strong enough to house 2 10" and 2 6"X9" speakers.
i no every one says just mdf and accoustic cloth but is that really the case?????
i have 2 options build myself or get a mate to do one for me but will cost 2 - 3times more money i just wanted advice and specific instruction on how to build/make stealth shelf.
J.C
Championboi
Re: Build a stealth shelf
Postby properphatboy on Fri Dec 14, 2007 2:43 pm
By 2 10" do you mean subs? If so this probably isn't a good idea at all if they're not designed to work in the open. You really should have them in boxes otherwise there's no resistance to their moving and they wont respond as they should and will sound awful.
I also wouldn't recommend 6x9's in a system with subs, as the only thing they can be useful for is adding extra bass to systems without.
It's not hard to make a stealth shelf though. Use 20mm MDF and your old parcel shelf as a template. You may want to use some extra MDF as shaped supports for your speakers, to double the thickness where they attach if you get what I mean. I'd recommend spray glue to stick the carpet on. You'll need some dowel or something similar, or maybe the things off your original shelf to attach it at the back. Do a google image search for some ideas and also do a web search there for guides too.
properphatboy
Your car: Peugeot 306 D L
Postby Championboi on Sat Dec 15, 2007 1:37 am
firstly i got the idea of subs on parcel shelf when i went to a sound show and saw 2 15" subs in a stealth shelf with 6x9's professionally done by vibe in a focus.
it looked and sounded awsome from then on iv been looking for the best way to do this.
i also do not have original shelf i was planning to make one just out of mdf the thing i needed to know is the sub will be air tight on the shelf but will i need a box under the sub for extra resistance or will shelf just be enough.
Championboi
Postby properphatboy on Sat Dec 15, 2007 3:26 am
If the sub is designed to go in a box you'll need a box. If it's a free-air model you wont.
properphatboy
