bumpstops for 16in wheels
7 posts • Page 1 of 1
what bump stops are people on here using with their fiesta turbos with 195/45/16s to stop rubbing?
theres a wide selection on burtons website but dont know which to get
thanks
gav
thanks
gav
- GavStyli
- Your car: Fiesta Turbo
- GavStyli
Re: bumpstops for 16in wheels
on the back i used grayston spring expanders used for carvaning and stiffend up the backend deffo worth the 15 pound
- HCS PIMP
1. Measure your current bumpstops.
2. Determine/choose how much of the suspension travel you would like to eliminate to resolve your problem.
3. Order bump stops that will allow you to do so (i.e. current bump stop length + this extra distance).
thats exactly what im doing sheman, theres a topic in Guides / FAQs which lists tyre sizes so im working out the size difference between std wheels and the 16s then add 1cm to be sure lol
- GavStyli
Coolio. I'd try to make it sound more complicated if I could, but it is only a simple operation, I'm sure you can order up and be done with it soon enough
- matty872
