Calibra Turbo Pistons
29 posts • Page 1 of 1
what conrods fit these piston in a zetec block??
- SEG1
- SEG1
why not just but the accralite forged pistons specifically for zvh and zetec turbo conversions. wouldnt that be easier???
- jonesy_rst
- Location: Stockport **fiesta rs turbo show car in the making**
- SEG1
jonesy_rst :why not just but the accralite forged pistons specifically for zvh and zetec turbo conversions. wouldnt that be easier???
£££££££££ £600+ for pistons like your talkin about
calibra ones are bout £100 max and the £90 to modift so that the gudgeon pins fit in.
the actual zetec block will also need boring out to 2045cc to fit LET pistons too.
run about 230bhp easily
- Jonezy
yeah i got a set for under 100 yesterday.
and im buying zetec steel rods.
what needs to be modified the piston or rod?
im also getting the block bored soon.
- SEG1
the rod needs to be modified, if you read above the little end (the end that attches to the piston via a pin also know as a gudjeon pin) needs to be bored out to 21mm, one question though how big is the little end in the first place? wont this weaken the rods? also wheres the best place to get some calbra pistons from im intrested in getting a set now
- adam_frst
the rods am using are 19.9mm at the small end.
i got mine of ebay £88!lol
check at breakers and ebay.
- SEG1
never like it when people talk about modifying rods, they were built and strength tested and made to work as they are , by adding and taking metal away your changing the molecular structure of the rods there for anything could happen they could be fine or ok.
this may just be me but why do people always try and build zvh and zt's on a budget, if you are going to build an engine isnt the best way to build it as strong as you can with components you are 100% sure of?
- White2i
FRSJON :cool, when you get it done post it up so i can see how much and where...mate of mine needs it done
there in the post now the guy i bought them off .is a longting!!
but when i get i will post them up with the rods and modifications.
- SEG1
- SEG1
those are XE pistons, not LET, so will give a ZT c/r of about 9:1
- Rhinopower
- Your car: Volvo FH330
- SEG1
yes with a decompression plate from ferriday engineering
- Rhinopower
- SEG1
- SEG1
- SEG1
- SEG1
