Cams/Bottom End.......
21 posts • Page 1 of 1
If you fit a performance cam am i right in thinking that it's also advisable to strenghten the bottom end ? ? ?
If so what actually needs to be done to it ? ? ? and would you advise uprating anything else? ? ?
[ERRR] i haven't got a clue
- Andy Si
Just a standard 94 zetcec 1.6 16v.
It just that im sure i read a post on here once that said "im fitting a cam blar blar blar"
and someone replied with "make sure the bottom end is up to it"
<font size=-1>[ This Message was edited by: Andy Si on 2001-09-13 08:38 ]</font>
- Andy Si
nah m8, everything should be kool just by fitting a cam....all that the cam will do is keep the valves open longer therefore chuck in more petrol and air hence more power....the bottom end aint gonna get harmed at all
what cam u thinking of getting?
bassboy
bassboy
- bassboy
- Authorised Trader
Andy - I would definately make sure your bottom end is ok first.
I've had a new cam & lifters on two of my cars - both of them ran sweet for the first couple of months then after a few raggin's the bottom end went on both of them
- zetec69
Yeah serious bassboy. It happened on my 1600 cvh & my 1600 cvh efi. My mate had it happen to his aswell. The thing is my mates dad gets new cams & lifters from work on the cheap so a lot of us have replaced ours but if you hammer your car the bottom end goes easily unless it's it top notch condition. Don't know why but it's happened many a time!
- zetec69
Yeah mate, if your putting a wild cam in, it's better to have the bottom end worked. This is because you move the peak power of the car up the rev range to about 6400 (with my piper 285 cam) So the car will spend more of it's time around this rpm, which is not good for a bottom end.
But saying this, I ran my car with a cam for over a year and never blew the bottom end, just take it sensible.
Mew
Moondust FRST/XR2i Bumpers WANTED, PM me
- gar mae
- Authorised Trader
Check Graham's site also, has some info on uprating the the rod bolts.
<!-- BBCode Start --><A HREF="http://www.zetecinside.com/xr2/zetectune.htm#rod" TARGET="_blank">www.zetecinside.com/xr2/zetectune.htm#rod</A><!-- BBCode End -->
-Andy
-Andy
- Andy_XR2i
Bassboy,
Im not to sure yet - proberly look @ Piper or Kent, but to be honest I haven't really got a clue
I want summit that gives a little less peak power, but improved mid range gains.
Anyone got any ideas ? ? ?
<font size=-1>[ This Message was edited by: Andy Si on 2001-09-14 06:53 ]</font>
- Andy Si
I have a Kent CVH31K cam which is a "mild" cam fitted and this has given me no problems and i have not touched the bottom end of my engine.......i am sure we all know how many miles i have so i wont repeat
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
- Tartan Turbo Terror
- Your car: mk2 Focus RS
Car: 2009 Ford Focus RS
I fitted the Piper T2 cam, and a week later my bottom end is going, but i dont think it is done to the cam, it was just speeded up by the cam... cause it was losing power a while before..
So as mentioned the cam quickened the bottom end blow up..
- Ian C70T5
- Das Ist Kapput
- Ian C70T5
- Das Ist Kapput
obviously, no matter what u do to the engine, it will shorten its life...especially performance wise...but like i said, weve never had a problem or a come back...all the cams and bottom ends are still going strong even over a year down the line
bassboy
bassboy
- bassboy
- Authorised Trader
i dont know if u care, but i put a new cam and lifters ect.. in my old xr2i and replaced literly everything in top half. a few months later the bottom half went. i heard of it happen to others too
- paul_watson
A cam, as we all know, makes the valves stay open longer, which allows more air and fuel to enter the cylinder.
This results in a bigger BANG in the cylinder which gives you more power.
But this bigger bang obviously makes more stress for the pistons, conrods etc.... so putting a "lumpy" cam in to a high mileage car is probably not a good idea. My car had done 104k when i had the head, cam etc done....but i only put a "mild" cam in so i hopefully didn't get problems and so far it has worked
1990 FRST : Sold.
1990 FRST : Sold.
- Fezzy Turbo
