Camshaft
21 posts • Page 1 of 1
Oranoco :A Kent CVH34 or Newman. Piper 285T2 is pants
Piper 285T2 isnt a good cam.
Kent CVH34 or the Newman's... they are really the oposite when it comes to top-end power!
CVH34 was originaly design by Ahmed Bayjoo cause there was no cam to replace the std one with similar std cam spec.
The Newman's one for the CVH turbo is the hottest cam around. You'll need a custom live maped chip for it if your keeping std management.
- BUTRE
BUTRE :Oranoco :A Kent CVH34 or Newman. Piper 285T2 is pants
where i can buy the newman or the kent cvh34
- turbors
turbors :BUTRE :Oranoco :A Kent CVH34 or Newman. Piper 285T2 is pants
here is a link
http://www.newman-cams.com but you will have to get the car live mapped otherwise your car will run like s**t. these are the best cvh cams you can buy.
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
turboboss :turbors :BUTRE :Oranoco :A Kent CVH34 or Newman. Piper 285T2 is pants
here is a link
http://www.newman-cams.com but you will have to get the car live mapped otherwise your car will run like poo. these are the best cvh cams you can buy.
I just wonder... even with the car properly maped (even using a better ecu than the std FRST one) will it pass MOT? I belive that in uk your cars must pass the gas emissions (1.5 of CO I think)... will this cam be ok?
- BUTRE
turbors :ok
ian Howell me A advises kent it cvh34 for my t25.
I really doubt that he fundamented is cam choice on your turbo. If you're running a 165 chip, then going anything wilder than the CVH34 cam will give you lean combustion at high rpm... detonation is not something that you would like to have.
the only safe way to go above "wild" is with a custom live maped chip to suit all your engine mods.
- BUTRE
BUTRE :turbors :ok
i have a cosworth mangement whit a live mapping ......is good no???
- turbors
CVH34 is to exchange the std cam and keep the all around good power.
CVH35 is for high rpm power.
CVH36 delivers a little less top end power than the CVH35 but gives you a better mid-range torque, which is better for revving.
The Newman cam is the "race cam". Top end and you'll only get back some mid-range torque if the car is properly live mapped. Escort MFI injection doesn't go too well with this cam.
- BUTRE
