Cant find Performance mainfold anywhere????
23 posts • Page 1 of 1
didnt know if anybody out there how can help me...
got fiesta 1.6 16V si 1995 plate. wanting to upgrade the manifold but cant find one anywhere?
- wantmorepower
Im using a trust electrcal four branch . expensive for what it is.
St170 will fit with some fudgekin about.
Rs1800 would be straight fit and be better than you have
- Sunil_FiestaRS_16V
As Sunil says above. But you must think about the fact that will it really make a difference to your car in terms of performance? Certainly not without some other major engine mods which to be honest will be very costly for the price. Most people will tell you that it would be better to swap the engine for say a 2.0 zetec but if you can source an RS1800 or 1.8 zetec manifold for next to nothing, then theres no harm in trying. It's your money.
- chumkila
- Dirty Post Whore!
Custom made is the only way to go if you want a 4 into 1
Mountune do a very good 4-2-1 stainless steel or mild steel one that was developed for the BTCC Focus's
- freak power
- chumkila
- Dirty Post Whore!
It's all done and just trying to find time to get it booked in for mapping when i'm not busy
- freak power
i would have sex with that engine bud!!!! lol
what you got running in it.
roughly how much money im i looking at to get it that way.
hands up to you. gorjous plan and simple
- wantmorepower
wantmorepower :roughly how much money im i looking at to get it that way.
Loads
Head work is over £1k
Forged high comp pistons £600
Steel rods £700
Custom manifold and zorst £700+
race cams £400+
Tappets, springs and retaners £500+
Throttle bodies, managment, mapping £1800+
Nologe plug leads £100+
The list goes on and on
- freak power
cheers bud, i think i better get saving to be able to afford throttle bodies like yours, think ill stick to 2.0L throttle body!!
- wantmorepower
freak power :It's all done and just trying to find time to get it booked in for mapping when i'm not busy
Come on lad get with it, we all want to see what it can do!!
- chumkila
- Dirty Post Whore!
chumkila :freak power :It's all done and just trying to find time to get it booked in for mapping when i'm not busy
I've got to run it in aswell Going to get it on the motorway to do that.
When do it should be fast, just got to get a CTS stage2+ box at a later date to get the times down.
I'll let you know what the Stacks says when done and then i'll do the group thrashes.
- freak power
I don't rate the Ashley ones
- freak power
Tryed and tested them, didn't perform that well for my needs.
The best 4-2-1 i've use was Mountune manifold
- freak power
Its like that for a reason.
The primarys have to be a X length and X bore so when you do a 4-1 the colector would be under the sump and that would reduce ground clearence, its that so the colector is in front of the sump before it forms into the the 2.5in pipe that runs under the sump.
- freak power
cheers boyz for the replys, mite try the Mountune manifold if not ill have to aford to splash sum cash and get my nearest performance tuning company to build me one.
update you with progress...
- wantmorepower
wantmorepower :mite try the Mountune manifold
..update you with progress...
- freak power
whats the mountune one like for fitting????
is it a case of having a custom exhaust place fitting it for me???
this is for an rs1800 spec lump,
- RS rob
- RS rob
It's not a bolt on and you might have to have a part of a pipe made up
- freak power
