car kangeroos when warmed up
7 posts • Page 1 of 1
i recently had a engine fitted its not yet been mapped/retuned
but wen the car has warmed up and go 2 go over 3000rpm the car kangeroos in affect
- lyonsfiesta
Re: car kangeroos when warmed up
Given the amount of information you've given us (!) I can only assume it is running lean, running rich, gearbox mount, engine mount, clutch, clutch cable, driveshaft, cv joint...............................................
- dontpannic
Yeah, Like it's all in the details dude ... or lack of faiirly large details like.. What engine/car is it?.. did you have the engine re-built or is it from the local scrappy? did you have it running/driving in the previous car to know whether it had a problem before the swap over??
The more info you give, the better chance you have of someone being able to help
- RS Joe
And to go on with the list...fuel pump,fuel filter,fuel pressure regulator faulty,spark plugs,spark plug cables...we need more info or else we will misslead you I am afraid And hit and miss practice isn't the best...
My Ford Escort ride
My Ford Escort ride
- georgiocat
hey all its a 1.6 turbo in mk3 fiesta was a 1.1
its a rebuild engine [ERRR] t3 turbo
not 2 sure if its over boostin
had it put on rollin road set up fuel etc but when it was on the rollers comin up 2 high rev's it wud lose power then bk on agen
- lyonsfiesta
lyonsfiesta :hey all its a 1.6 turbo in mk3 fiesta was a 1.1
Hi,
You say was a 1.1 is now a 1.6? Questions, the answers to which may help someone to help you:
Which engine is it: (it could be one of many sensors, but each engine has it's own sensors)
What clutch/Gear Box Have you tied to engine:
What running gear have you used: (You've moved from 1.1 to 1.6) this must have changed
What loom have you used:
What fuel rail and injectors are you using:
What clutch:
and on and on and on.
There are more than one 1.6 and more than one of everything mentioned above and more than that. Did you buy the car ot MOD it yourself, if you did it you should know all that went in to it
Dave
- grandman
As above,but I also think that you should have a look at the engine and gearbox mounts too.Didi you replaced the fuel pump also?Because if you still have the 1.1 pump,the engine won't have the right amount of fuel needed,and you could have problems soon...
My Ford Escort ride
My Ford Escort ride
- georgiocat
