car shudders under harshish braking
7 posts • Page 1 of 1
if i apply a fair bit pressure to the brakes the car starts to shake, do i need new pads? It is a 1.6 si cheers
- Mrtitty
Does your car have ABS?
If so the brake pedal will shake about a bit when the system kicks in.
Otherwise what you are most likely feeling it a warped disc at the front. Change both the discs and the pads. Should only cost £40-50 or so from your local motorfactors for the lot.
- Stoned
Does it grow from a bit of a judder and pulsing through the pedal to harsh shaking, or is it an "on/off" type of thing? If it's the latter, you must be into your ABS. If it's the former, new discs are the most likely cause.
im having the same trouble with mine. ive got cossie front brake set up and rs2000 rear set up. the steering wheel shakes ALOT when i brake. i know i need to change the rear pads cuz theres nuthin left on em but if it still happens then i know i need to change the disc's.
- dee 2i
