Car sounds like a scobby when reving
Postby Farooq on Wed Apr 03, 2013 2:39 pm
The fiesta xr2i 8v sounds like a scooby when reved. The timming belt was replaced not long ago could it be related. The car also recieved a full service inlcuding plugs.
Anyone shed some light. Can idles perfect.
Farooq
Re: Car sounds like a scobby when reving
Postby Misterk on Wed Apr 03, 2013 5:50 pm
Sounds like it could only be firing on three cylinders, could be HT leads
Misterk
Your car: Fiesta rs turbo zvh
Postby reithy on Wed Apr 03, 2013 8:55 pm
I'd concur sounds like leads or plugs. Mine did it on a zetec and was the leads
reithy
Postby Farooq on Thu Apr 04, 2013 4:09 pm
new plugs buddy, il clean up leads, and connectors and earth. cars sat for a year, so gave it a service. Could a f**cked ignition relay contribute to the problem?
Farooq
Postby reithy on Thu Apr 04, 2013 9:47 pm
I had to buy a brand new set of leads and it solved mine
reithy
Postby mikeymikeyp on Fri Apr 05, 2013 9:37 am
if its firing okay id pull out the lifters and check the bottom of them for holes
mikeymikeyp
Postby Farooq on Fri Apr 05, 2013 9:54 am
Brand new lifters
Farooq
Postby jammy86 on Sat Apr 06, 2013 3:13 pm
IGN coil pack or leads. My other halfs Ka did this a while back. Revs OK under no load, sounds like a scooby when you drive it.
jammy86
Your car: KaRST
Postby jayrs on Thu Apr 11, 2013 9:30 am
My RS started to sound like a scooby on the way home from ford fair some years back, turned out a lobe had worn out on my Kent cam, pi$$ed me right off seeing as it hadn't don't a thousand miles.
Fitted new cam and lifters to sort mine, might be worth a check on the lobes around pot 3
Other than that as what's been said, check leads and plugs, could maybe even have a injector at fault
