Car will not rev.
Car will not rev.
Postby farleyj on Sun Apr 14, 2013 3:00 pm
Frst cuts out as soon as i touch accelerator pedal. At my wits end now. Its all standerd apart from dump valve and s/s exhaust. The wiring loom is abit dodgey but i have tested it with multimeter and everything seems ok and going were it should. Could a faulty fuel regulator cause this problem. Plugs get sooted up fast. Any 1 live in birmingham who knows about these on here??????? Please help because i feel like taking a hammer to tge bloody thing
farleyj
Your car: 91 frst nova gsi transit conn
Re: Car will not rev.
Postby mikeymikeyp on Sun Apr 14, 2013 5:32 pm
If the plugs are sooty and black then its over fuelling mate :)
mikeymikeyp
Postby jayrs on Sun Apr 21, 2013 6:54 pm
Could be a number of things, like the TPS, air leak, ISCV etc
Postby fezzRS on Tue Apr 30, 2013 9:46 pm
Getting too much fuel then is the engine lumpy on tickover map sensor does the car have a chip take chip out re rry it unplug tps and see if it revs what is it actually foing wheb u try to rev itvdoes it bog down done a service
Your car: run about
Postby fezzRS on Tue Apr 30, 2013 9:49 pm
I dont live to far from brum mate have a fault code reader might pick up sone codes
Your car: run about
Postby fezzRS on Tue Apr 30, 2013 9:51 pm
Cutting out when trying to rev it wud indicate tps mate try unplugging the tps start car then rev it it [ERRR] rev if its that
Your car: run about
Postby farleyj on Wed May 01, 2013 9:38 pm
thanks for the replys. think i have found the problem. the feul pressure regulator is not letting fuel return to tank. if i pull return pipe off no fuel comes out. pipe is dry as a bone. got a new 1 on the way now. will update if works. thanks again.
farleyj
Postby fezzRS on Sat May 04, 2013 10:39 pm
Theres either too much unburnt fuel in there or not air getting ib check the intercooler
Your car: run about
Postby farleyj on Sun May 05, 2013 12:06 am
fezzRS :Theres either too much unburnt fuel in there or not air getting ib check the intercooler
Changed fuel regulator. No change. Did google search on map sensor and seem to be getting symptoms of a faulty 1. What i have noticed tho. When car is idleing it bogs down and splutters and will not rev under heavy acceleration but if i remove the positive lead on battery then reconect it the car will rev perfect for a minute or so then goes back to way it was?????????
farleyj
Postby jayrs on Sun May 05, 2013 9:24 am
That's because you basicly reset the ecu and clear the fault.
When it detects the fault again it goes into save mode. Or that what it sounds like to me
