carb for hcs
13 posts • Page 1 of 1
carb for hcs
reading the months classic ford and some blokey asks what engine will go in his motor for a power increase, they suggest the brilliant hcs they go on to say that you can fit cams (knew that) but they also say you can fit a weber carb, it doesnt say what type, does anyone have any idea which one it is?
6 Point Safety Devices Cage.
- purple_fiesta
- chris-fiesta
i can afford something better but cant get insured so im wanting it to play with in the time being.
- purple_fiesta
id have thought you could fit a webber carb very easily to a hcs. wouldnt you just need a inlet fanimould off a earlier 1.1, 1.3 or 1.6? a 1.6 off a mk1 xr2 would be better as it will aready have a twin choke webber carb bolted to it. might have a problem with fuel pressure though so will probably need a regulator. the only thing im not sure about is if the manifold bolt pattern off a earlier ohv is the same as a hcs. would think it was but nevver compared them to know. other than that, may need slighty smaller jets if the hcs has got a standard cam. those two would make quite a difference id have thought
- 285Andy
- Your car: fiesta rs turbo
and it was alot more powerful than the pissy carb i have now!! Only thing that limited the scort was its poo 4 speed gearbox
- bakewell001
My first Fiesta was a J-reg 1100 and it had a Webber carb as standard. It was the TLDM and was the same carb that went onto the mk2 XR2 except it had slightly smaller jets. Suggest getting a carb off a mk2 XR2 or a mk3 1.6s.
YRN Thread - yrn-vt151433/
- Ollybee
Car: 1996 Ford Fiesta Quartz
Looking at the reg of your car, id suspectits got CFi, which means it has a cat, which means, if you fanny about fitting a carb, you'll never pass an emissions test in a month of Sunday's. Yes Weber do uprated carb kits for the OHV engines, available through their dealers, Southern Carbs and Injection would be a good place to start. But if you do want to go down that route, you will have to change the engine for an earlier OHV engine, pre-emissions spec.
- Pez
Pez :Looking at the reg of your car, id suspectits got CFi, which means it has a cat, which means, if you fanny about fitting a carb, you'll never pass an emissions test in a month of Sunday's. Yes Weber do uprated carb kits for the OHV engines, available through their dealers, Southern Carbs and Injection would be a good place to start. But if you do want to go down that route, you will have to change the engine for an earlier OHV engine, pre-emissions spec.
J plates can quite easily have carbs, and therefore no cat
John
Audi quattro turbo
- bowdenj
bowdenj :Pez :Looking at the reg of your car, id suspectits got CFi, which means it has a cat, which means, if you fanny about fitting a carb, you'll never pass an emissions test in a month of Sunday's. Yes Weber do uprated carb kits for the OHV engines, available through their dealers, Southern Carbs and Injection would be a good place to start. But if you do want to go down that route, you will have to change the engine for an earlier OHV engine, pre-emissions spec.
John
J plates DID have carbs, no doubt, but his car is N-reg, just been through the Photoshop mixer
- Pez
