cast 1800cc zetec piston crown thickness
7 posts • Page 1 of 1
will 6.34mm be able to hang onto 13-14 lbs of boost ok? or they just gonna blow through?
thank ye
thank ye
- 285Andy
- Your car: fiesta rs turbo
ive not taken anything off them yet but 6.34mm is what will be left after ive taken 2.5 mm off them if you see what i mean their actual thickness before machining is 8.84mm.
ta muchly
ta muchly
- 285Andy
should be fine up to about 1 bar of boost mate, if you want them to last a little longer i suggest ceramic coating. stops heat entering the piston crown but make sure you have a decent I/C because it tends to heat everything up if you dont.
Ross
Ross
- Ruishy1
Fine with 1 bar.
What are you building Zetec turbo or ZVH ???
- freak power
just a very cheap zetec turbo i just need to know what there like so im biting the bullet. the cvh in the car needs a rebuild so i thought what the hell. new pistons for turbo cvh cost 450 odd quid plus skimming at another 25 quid a piston for low compression so it seemed a good idea at the time when i was offered a 1.8 zetec from a xr2i
1 bar max will do for me just fine. thanks very much fella's
- 285Andy
this guy on ebay does the ceramic coating, my mates ZT has them, 2ltr, calibra pistons, rs500 cooler, FRST management with custom chip. and it hasnt missed a beat. apart from when he crashed into the back of a pug
http://stores.ebay.co.uk/MD-PERFORMANCE ... esstQQtZkm
- Ruishy1
