chatter and dumpvalve
23 posts • Page 1 of 1
just a quick question can you have both? i know what creates chatter but can you still get it with a dump valve fitted
- trossnova
Re: chatter and dumpvalve
In short no. the chatter is the compressor blades stalling by the boost having nowhere to go when the throttle gets closed. add a dump valve and you get rid of the chatter and also look a bit of a 'conquering device'.
- edders
In short yes. If the spring in a atmospheric piston type dv is too strong you get a some charge air being released and some backing up behind the turbo. In one of heeman10's vids you can here his re-circ DV dumping but still chattering.
Ex Fiesta RS Turbo owner
- filtra
as above...
If the dump valve is so tight that it will only open at 20 psi boos to less than that and it will flutter, anything over will dump...
Do away with it all... just stick to chatter!!
x x
x x
- Shell
as said yes it can be done...i have the best of both worlds chatter and then ptttssshhhh LOL or i can get one or the other...depends how i play with the throttle
bassboy
bassboy
- bassboy
- Authorised Trader
and last but not least it's proper name is Compressor Surge not Chatter
I have parts for sale!!!!.....Nice parts too!!!
http://www.fiestaturbo.com/forums/lots-of-parts-for-sale-vt185591/
- MattPym
MattPym :and last but not least it's proper name is Compressor Surge not Chatter
Actually it's called compressor stall, surge is the process of air backing up behind the blades but it's the stalling of the blades that cut the air to create a noise which is beautifully described by words such as chatter or flutter or wokka
- filtra
My car does it when i stick my dump valve in
- j7aoc
Feersum_Enjin :MattPym :and last but not least it's proper name is Compressor Surge not Chatter
Rather than going against you on this i'm am going to combine the words and now the technical term shall be Compressor Starlge
I'm sticking to surge though
- MattPym
Compressor surge is a completely different thing which relates to the turbo used.... will do a Wardy257 and get details about it, sure I've got what it is in a mag somewhere
- SiZT
It's the sound of the air being pushed back through the turbo causing "compressor stall", surge is something different alltogether
Oranoco :It's the sound of the air being pushed back through the turbo causing "compressor stall", surge is something different alltogether
Please enlighten me if you dont mind so atleast i know the difference between the two!
- MattPym
As far as i'm aware 'surge' is when the engine cannot use as much air as the turbo can produce...
I'm sure someone will correct me if i'm wrong but they are the basics...
x x
x x
- Shell
shell :As far as i'm aware 'surge' is when the engine cannot use as much air as the turbo can produce...
Someone get this lady a prize
x x
Ahh i see....
Thank Oo
- MattPym
heeman10 :shell :As far as i'm aware 'surge' is when the engine cannot use as much air as the turbo can produce...
I'd prefer some sort of badge...
x x
- Shell
x x
Correct but you already know that.
shell :heeman10 :shell :As far as i'm aware 'surge' is when the engine cannot use as much air as the turbo can produce...
x x
hows this! (man im good at these badge things )
- 285Andy
- Your car: fiesta rs turbo
x x
if only all girls were like this
- SiZT
SiZT :Compressor surge is a completely different thing which relates to the turbo used.... will do a Wardy257 and get details about it, sure I've got what it is in a mag somewhere
Ive just spat coffee at my screen!!
- Ratspeed
SiZT :shell :As far as i'm aware 'surge' is when the engine cannot use as much air as the turbo can produce...
x x
If the forums were bombarded with girls thinking they knew what turbo surge was and giving it a go at answering... we'd be in trouble...
x x
- Shell
so as im a complete nonce and openly admit i know nothing about turbos...the sound a cossie gives standard is chatter, but if one so chooses to put a dump valve on, the it makes the pschchhhhhhhhhht noise lol
just need some really sad ammo to put of an ugly girl
- volcomstone411
Mine used to chatter and dump when the diaphragm split on the dump valve did sound kinda cool.
- JamieFRST
- Keep It Tidy
