Cheap / Uprated Gearbox Mounts
Postby ben0307 on Wed Nov 19, 2014 6:48 pm
I've broken a few gearbox mountings on my Fiesta Si, so have been looking at possible alternatives that may be a bit more robust. Didn't really want to spend £100 on a pair of Vibratechnics mounts though.
Turns out that Land Rover V8 engine mountings are a direct replacement. Same threads, and almost the same thickness (maybe a millimetre or two thinner). They also appear to be made of harder rubber than the ford part. ANR1808 is the part number.
I have fitted a pair of these, and so far they seem to be working well. They do transmit more noise and vibration - as you may expect - but movement of the engine and gearbox seems to have been reduced. Only time will tell how well they last, but they have been on the car for my last 3 motorsport events, and they seem fine.
The best part about this is the cost:
Vibratechnics mounts - £50 each.
Standard mounts (non-genuine) - £25 each.
Land Rover mounts - £4 each (including delivery) from ebay.
Some people may already know about this, but I haven't seen it mentioned on this forum before, so thought I should post the info in case it helps anyone else out.
Some photos below:
Land Rover mounting on left, Fiesta Si mounting on right
Front of cradle
Rear of cradle
Front of gearbox
Rear of gearbox
ben0307
Re: Cheap / Uprated Gearbox Mounts
Postby mikeymikeyp on Sun Nov 23, 2014 10:15 am
thanks for that :)
mikeymikeyp
Postby Smo on Wed Nov 26, 2014 1:45 pm
Good find! I didn't know about these at all. I've got Vibratechnics, but it's well worth knowing! :)
Smo
Postby ben0307 on Sat Jan 31, 2015 11:26 pm
These mountings didn't work out as well as I hoped. Ripped the front one in half after 4 months (8 events).
I guess you get what you pay for - I wouldn't recommend them for motorsport use.
ben0307
